Mach Discussion => General Mach Discussion => Topic started by: jimmyg on December 16, 2005, 04:06:27 PM
I am an old Master5 user (three years or so), on a home-built plasma cutting table, like a big plotter. It is 2 axis only, I run the vertical axis motor manually.
Question: Besides operating on a Windoze XP platform, is there any advantage to me to upgrade to one of the Mach packages? One thing I would like is to have cutter compensation built-in, instead of having to pre-process for compensation. Does MachX do this? What other neat stuff am I missing using the old Master5? Which version of Mach do I want to start with?
Thanks for any hints, suggestions, opinions.
Comp is working MUCH better than Master5 :) There is such a long list of thens that have been added that you are going to have to download it and play around...
You will not have to pay for the upgrade:)
Thank you
Brian
you sure he doesn't have too? as i remember master5 was cheaper than mach1
The cost change make no differance... Art never charges for upgrades.
Brian
Sorry about that Barker didn't see you were a admin :) Heck if anyone should know whats going on you should :) Hard to remember back 3-4 years hehe
No problem :)
Brian
So I can upgrade to Mach 3 at no charge? All options would be unlocked? (conversational and all the wizards)
That is an addon so it is not part of it :( That also is not Art's work...
Hope that helps
Brian
ahhh...I see. ;)
Didn't realize that until now. Sorry about that. :-[
But in regards to mach 3, how do i go about updating?
