Mach Discussion => General Mach Discussion => Topic started by: panaceabeachbum on September 10, 2008, 10:40:44 PM
I am using the lathe silver/blue screen set and would like an MDI line on the auto screen . The black bar across the bottom right side of the screen list the path for the file thats open , can I easily change it to an MDI line so I dont have to go thru the 2 or 3 button clicks to get back to the manual screen?
Should be easy enough in screen 4. In the tool bar on the left side in screen 4 you will see MDI line. Just drag one in and size and posotion it. First thing I would do is open the .set you want to edit and save as soemthing different like ricks screen and work on the one you saved that way you allways have the original to fall back on. Then when you have it like you want, open mach and go to view and load the screen you modified.
thanks it really was just that easy
:) Ain't it great?
