Mach Discussion => General Mach Discussion => Topic started by: wlarry on August 24, 2008, 01:59:57 PM
As usual, fixing one issue caused another. My A axis of my gantry is intermittantly loosing steps and only when travelling in one direction. Initially had a lot of PC problems optimizing to get mach happy. So I upgraded to a Dell Optiplex 260. I installed mach (latest version - tested) and the THC300 bitmaps and files. When I open the THC300 set, the screens are missing buttons. The program screen is missing the e-stop reset button, reference home keys and other screens are missing keys as well. Tried to reinstall a couple of times - no change. Made sure thc bitmaps were coppied into bitmap directory - no luck Worked ok on the last system ? Anybody have any thoughts ?
Can you attach your screenset to this post, I have just had a look at the screen I have in screen 4 and it looks like maybe the path for the bitmaps are wrong so I would like to compare to yours.
Thanks for the help Hood. I did a re-install of MACH and everything seems to be behaving. Can't explain what went on.
Thanks everybody for your help.
