Mach Discussion => General Mach Discussion => Topic started by: MJR on June 03, 2006, 07:16:25 PM
I have tested Mach3 using my older 1000mhz system going thru a Logitrol stepper package for my cnc router. I has worked perfectly. Did not need to go & fine tune anything. Before I fully register & purchase Mach3 should I consider updating/upgrading my computer?
Would appreciate any thoughts & comments on this.
Thanks.
If it works then use it :)
Mr Hood:
So I can assume that my current computer should handle Mach3 for quite some time then. I guess my limitations will probably be with my designing software. Maybe a separate computer for that purpose may be the answer in the future.
Talk to you later.
