Mach Discussion => Mach SDK plugin questions and answers. => Finished Plugins for Download => Topic started by: poppabear on August 02, 2008, 01:49:04 PM
Greetings,
This plug in is a Smaller cousin to the Modbus one, It will allow Independant Jog speeds of up to all 6 axis, but you can use it on the Parrallel Ports!!!
You can use it for Independant Axis Jogspeed scaling from Emulated Keys, or real External Inputs through the PP.
It includes Example:
1). MachScreen: "1024IndependantJogPP.set"
2). XML: "IndependantJogPP"
3). Flash Help File that has a Walk through tutorial on setup and use, with pics.
Just down load the installer, and install.
The Installer called: "IndependantJogPP_vs_1.1.zip" is attached to this post.
NOTE: Fixed the installer, in where you can download and install it to any Directory that you have mach3 installed in, the Plugin Help files will now connect to that different location.
Scott
Scott
did some testing eventually ::)
I was using the PoKeys to put physical button as jog keys in on Port10 and it worked exactly as it should :)
SWEET!!!!
I was wondering about if it would work with Po-Keys...... I didnt know if the port 10 stuff would throw stuff off.......
Scott
BRAVO Scott ... bravo !
Very handy piece of work you have done here.
I'm missing the bitmaps from the RUN screen and the "extra" screen.
The Flash help stuff is excellent !
Russ
