Mach Discussion => General Mach Discussion => Topic started by: timothysvec on December 06, 2005, 01:57:20 PM
Where is the motor reversal box located? Mach2 has it in configuration…….
I love mach2 but wanted to stay up to date and use mach3. do i have to switch the wires on my drives?
Cheers,
Tim svec
They are in the config--> homing/limits, there is a column that says reversed, you can add a checkmark to the ones you want reversed.
Hope this helps
Fernando
The other way to change this is under the ports and pins Active Low setting for the Dir pin on that axis...
Hope that helps
Brian
