Mach Discussion => General Mach Discussion => Topic started by: slammers on June 22, 2008, 01:10:36 AM
I need to use a second enable line for my lathe. For some reason when I activate enable2 and give it the port and pin I want to use, the enable2 led will not turn on in the diagnostic screen nor does the output change state when I reset the machine. This works fine when I run Mach3Mill but does not work when I run Mach3Turn.
Can anyone suggest what I may be doing wrong?
Shawn
I don't know - I have just tried enabling "enable" on both my Mill Screen and Lathe screen and both worked OK. I am trying this on my "office" computer - not in the workshop.
However on both my screens (1024.set and 1024.lset) only three of my enable leds lit up out of the six, even with all enabled.
I tried active high and active low - but it made no difference to anything. The leds were still lit (or not)
There was one thing I did notice and that was the settings were common to both set and lset, so whatever I had set on the mill transferred to the lathe when I changed the screen. Are you trying to get different settings on different screens???
I am not exactly sure how setting get changed between the mill and the lathe. When I installed mach3 it put 2 icons on my desktop, One for Mill and one for lathe. I have been using the Mill profile for years with my Taig mill. I just got a MaxNC lathe so I have been trying to set that up.
When I switch from one to the other the settings are definitely not common. Any changes I make only affect the one profile.
Shawn
Never tried with two enables in Turn before but have just tried and I get the same result. ie 1 changes with reset but 2 never changes. Will see what I can find out from Brian.
OK just talked to Brian, he says axis needs to be enabled and then it sunk in. Enable 1 will be mapped to X axis and Enable 3 is mapped to Z axis.
Thanks, that fixed the problem. I enabled the Y axis motor even though it is not connected and now enable 2 works. I do not understand why it is this way but its working now.
Shawn
Mach started off as Mill only, well actually it was probably even before it was called Mach. In Mill X would be mapped to enable 1, Y to enable 2, Z to enable 3 and A to enable 4. When Mach Turn came on the scene it was probably easiest just to leave things the way the way they were, might have needed a lot of code changes otherwise. Because Turn uses X and Z axis then all you need to do is use enable 1 and 3, you dont actually need to enable the Y axis but if it works for you that way then go for it :)
