Mach Discussion => General Mach Discussion => Topic started by: sacados on June 21, 2008, 12:02:24 AM
i am using Mach 2 on a small taig mill.It seems to cut everything backwards and 37.7 % too big.That seems to be the ratio of mm to inches.currently I am flipping and reducing my files prior to generating toolpaths with artcam.i figure there is a fairly straight forward solution, but i haven't found it yet.ideas?
Do you have any values other than 1 in the scaling DRO's? (program run page top centre)
Are you working in MM or Inches ?
Have you calibrated your motor tuning ?
If you go to MDI and enter G91 G00 X1. how far dose the table move 1mm or 1 inch or ?
Graham.
I have been struggling with getting my Taig MicroProto mill running reliably. It seems that every time I go to use the mill, new problems arise. The first time that I was able to get the unit running, it worked great for about a day. The next time that I went to use the mill, I noticed that the inline fuse in the controll box failed each time I turned on the machine. I thought this might suggest a short somewhere in the circuit, but after having someone with an electrical background look at it, we couldn’t see anything that was wrong. Does anyone know why this is happening every time I turn on the machine? Is this a voltage issue? I tried adjusting the potentiometer but nothing seems to make a difference. Could the motors be bad and causing a short?
I have been struggling with getting my Taig MicroProto mill running reliably. It seems that every time I go to use the mill, new problems arise. The first time that I was able to get the unit running, it worked great for about a day. The next time that I went to use the mill, I noticed that the inline fuse in the controll box failed each time I turned on the machine. I thought this might suggest a short somewhere in the circuit, but after having someone with an electrical background look at it, we couldnt see anything that was wrong. Does anyone know why this is happening every time I turn on the machine? Is this a voltage issue? I tried adjusting the potentiometer but nothing seems to make a difference. Could the motors be bad and causing a short?
It could possibly be 'inrush current' - try using a 'slow-blow' fuse of the correct rating.
What Tweakie says.
Roger
