Mach Discussion => General Mach Discussion => Topic started by: oskie on May 30, 2008, 05:19:26 PM
I have a customer that is running plasmacam and would like to buy one of my cnc tables, he would like to simply convert all his legacy files over to Tap files. I have been trying to learn mach3 to see if I want to change from Deskcnc and also would like to know where to change the rapid movement distance for the z axis, it is set at 60 in default( not sure why). If any of you are able to help in any way that would be very helpful.
Can you attach an example of the plasmaCAM file, might be that Mach can use it as it is, if not then maybe someone seeing the output code will be able to recommend a converter.
Not sure on your other question, what exactly are you meaning by the rapid movement distance?
I tried to attach a file, but said the*.pcm was an extension that was not allowed to upload, am I doing something wrong?
I will try a different approach, once the machine finishes a pocket, the Gcode wants to drive the z axis 60" up before it moves to the next pocket. Once it arrives to the next pocket it then wants to drive the z axis dow 60". My z axis is only 5"
OK sorry about that, I have now allowed pcm files to be attached to the forum so you should manage now, just for your reference if there is a file that the forum wont accept you can zip it and it will attach OK.
Your Z going to 60" between pockets is because the G Code is telling it to do that, what do you use to generate your code?
I was using lazycam to convert from DXF to TAP - here is the pcm file.
I looked in Lazycam, but couldn't find any setting for z dimensions. I have included a pcm file for you to look at.
Thanks for your help,
Sorry dont use LazyCAM so cant say where you will set the Z height but it has to be there somewhere.
Had a look at the pcm and have done a lot of google searches but come up a blank with that as well :(
Is the pcm you have attached the actual code that the plasma runs from or is it some form of drawing file?
I believe that it is the actual machine code, I can't get hold of him to verify. As soon as I find out I will send a reply
