Mach Discussion => General Mach Discussion => Topic started by: Kristin D on May 14, 2008, 04:58:20 PM
Just wondering I have a bunch of U shaped opto switches I bought surplus, if I put a disk on my spindle with either a slot or possibly drilled holes will inputing that to Mach provide a RPM readout? I'd go play with the program but it's hot back where it is today and I don't even want to step into the room till later after the sun is off that wall.
Kristin
Yes, see my reply here http://www.machsupport.com/forum/index.php/topic,6789.msg44448.html#msg44448
So if I install a disk and sensor I can calibrate it to give an RPM readout? Cool, I don't think I can incorporate speed control though as I don't have any documentation on my DC motor controller and it needs to start from zero or it just does not work, I suppose I could cobble up something like a D/A converter to drive the input further down the road.
Kristin
No need to calibrate it, Mach will see one pulse per rev so it will know what speed you are doing :)
Thanks, now if it cool's down in the "LAB" I will have to go back and experiment later.
Kristin
Another question, I would rather not have a notch in the disk, could I for instance drill (2) 1/8" holes and file out between them, it would be more user friendly should I lay my hands upon the spinning disk.
Kristin
You will need more than 1/8" wide or at high speeds Mach may miss it. If you drilled a 3/8" or 7/16" hole and then squared it off with a file it should work fine as long as you get the opto lined up properly.
Well it looks like a 1/8" hole might work for my application, I am running this on a taig lathe probably not going to exceed 3500 RPM, so from the website the slot width or angle is (alpha=.0012xN) or 4.2, so with my 2.5" diameter disk should be (W=.0088x alpha x dia) or .0924, I still may drill 2 holes next to each other and file out between them to increase my capability to say 5000 rpm when I am not using a chuck. Please check my calculations math is NOT my strong point! I just didn't want to make a finger remover by making open slots which is why I am looking at keeping this compact and using drilled and filed holes.
Try with that size and if you have problems make it bigger, some people get away with smaller slots than others, I suppose there are many factors that come into play. I have always made the slots approx 3/8" wide and never had a problem so thats why I suggested it.
Be sure to let us know how it works out
Wondering about powering this up, I have a USB cord from another project and was thinking (dangerous unto itself) that would be a safe place to get the +5 VDC for the LED in the opto and also either ground or +5 for the input without worring about floating grounds between supplies, I don't want to take anything off the controler board and let out the magic smoke. Do I need a resistor in series with the photo transistor going into the LPT port or can I just wire it directly. I will use a 220 Ohm 1/4 w for the LED and am planning on doing a comb test, running a hair comb through the sensor to see what is going on before mounting it to the machine.
Kristin
Yes USB should be fine for the power. As for the resistor it will depend on your opto, the ones I use have a 10K pull up resistor built in.
The more I look at this the more confusing it gets, looking at the schematic for the HobbyCNC Pro board the input pins are all pulled high with a 10K SIP resistor pack, so it is looking more and more like I would not want to draw power from the PC supply and just pick off +5 from the controler board for the LED and wire the phototransistor from ground to input w/o any resistor or perhaps just a few hundred ohms for safety's sake. Last thing I want to do is fry the on-board port, I have a seperate card but It didn't seem to work last time I tried it, Have to check the address and settings again.
Kristin
