Mach Discussion => General Mach Discussion => Topic started by: whatda? on May 08, 2008, 12:01:58 AM
Does Anyone know ,or can point me in the direction/post etc
to finding out how to configure/connect 12volt Proximity sensors
to a standard Breakout board.
I cant understand how to wire the one wire input (from the sensor) and
make it 5volts so the board can read it.
Any help ,would be great.
Regards
Whatda
Further to my question,the sensors output wire indicates 3.5 volts when the axis
is of the sensor ,and pretty much 0 volts on the sensor.
On connecting this wire up to one of the inputs on the bb,the voltage drops to 0.75volts.
Any ideas
Regards
Whatda
Safest way to find out would probably be to contact the maker of your breakout board and ask them.
How many wires have these sensors got and what is their specification - is there a 12v and 0v connection with another wire as the output.
What are these sensors so I can look them up.
Most sensors of this sort - optical, proximity etc - work on a negative "ON" - i.e. when they "sense" their resistance goes low.
The pins on your breakout board should be normally high +5v - to reflect the fact that the input pins on LPT1 are normally high - they have an internal pull up resistor. Is the input pin you are connecting to normally at 5 volts ???
The input to Mach 3 is at 5volts - I cannot understand why you are using 12 volt sensors - unless all the proximity detectors are 12 volt devices.
Thanks guys for your input,
Hood.
I have tried this,and he cant give my a clear answer???
Jimpinder
The reason for using these 10-30volt prox sensors,were that they came with the machine ,operating with a
very basic hand controller on 24volts ,and now I have converted over to Mach .
So before I go and rewire new switches I thought I would see if there was some way
of keeping them
The sensors are Omron TL -05MC1-2 , 3 wires (ie 10-30volt, 0 volt, and output)
and have attached the pdf file for them.
Also I believe the input pins on the BB are low.
Any help before I re wire some switches would be good.
Thanks, regards
Whatda
According to the PDF file these sensors connect to 12 v and 0v with an output wire. The module will drive up to 100 milliamps.
It should switch between 12 volts (NOT sensing) and 0v (sensing)
Connect up on your workbench the 12 and 0v to a suitable power supply and connect your multimeter between the output and 0v. You should get 12v reading. There is no directly connected internal pull up resistor - so the 12 v side perhaps will not show up. Move a metal (iron) object towards the sensor and the reading should change when the object is approx 2 mm from the sensor.There is also some detection indicator on the device.
The voltages will be approximate, not exact - but should be near say 11.5 and 0.5v.
To limit the pull up to a suitable voltage, then you need a pair of resistors in series connected between the 12 volts and the 0volts wires. These should be of the value 680ohms and 470 ohms (preferred values). The output of the device should be connected to the junction of this "ladder".
If you check again with you multimeter the output should now be at 5 volts and when you bring the object within sensing range this should drop to 0v (or very near).
The problem is your breakout board - the input should be normally high (5v). This is what the input to the computer is . The signals goes low to indicate sensing. Read the blurb on your breakout board - there will be some way to alter the bias on the board.
jimpinder,
This is excellent information,thankyou. ;D
It all makes sence now, as they were working with the G100 ,providing 12 volts back to the digital input.!
I would of kept the g100 ,however it had problems talking to mach or the other way,not sure,and when it
did sensed the switch it always did something different.
............................... a pair of resistors in series connected between the 12 volts and the 0volts wires. These should be of the value 680ohms and 470 ohms (preferred values). The output of the device should be connected to the junction of this "ladder".
I am trying to get a picture in my head as to what this would look like, any chance of a rough sketch to easy my elec.. challenged mind.
And then ,does the output go to one of the inputs to the BB.
Thanks very much for your info
Regards
whatda
If You are using a board similar to CNC4PC's C11 try this. Connect a 330 ohm resistor from the 5v terminal to the input along with the proximity switch output (black wire). Then connect the proximity switch common (blue wire) to both 12 volt common (from Your sensor power supply) and 5volt common on the BOB. Do NOT connect to the 5 volt common that gets power from the computer as it will defeat isolation. Then connect the brown wire from the switch to the 12 volt sensor power supply.
What this does is use the pull-up resistor to turn the input on, and the open collector output of the prox switch to pulll the resistor to ground to turn the input off. You may need to reverse the state of the inputs in Mach. (active low to active high) to get everything working correctly. All switches will need to be wired in parallel, connecting all three wires in order for this to work. This is not really the best way to make this connection, (as a broken prox. wire will not fail safe), but it involves the least wiring effort.
With this method, the input led should be normally on, and turn off whenever any of the prox switches are activated. If You have a different BOB, then this scheme may not apply. Go slowly, try connecting the resistor only first and see that the input turns on. Then connect a single switch and verify that the led goes out when the switch is actuated. If all is well so far then go ahead and connect the remaining switches.
Kenny
Thanks Kenny,its actually a C23 ,from the same mob,
I will give it a go though,thank you
Regards
whatda
Kenny - I think I've missed something in your explanation - I've drawn out your diagram and have got the input to the Bob pulled to 5 volts. The problem is the proximity switch activates - i.e. pulls low, when the chunk of metal goes near it. Not the other way round - so while I agree that electrically this would work as you say, mechanically it will not - becasue I assume you are detecting the fact that something has come within 2mm of the switch - not that it has gone away.
Attached is a diagram of my thinkings about it. As I say the output is normally high and goes low when activated. Try connecting to an input. The pull up resistor shown may be strong enough to pull your Bob to 5 volts as it is. If that is the case it should work OK.
The BOB has an led with a 330 ohm current llimiting resistor in series with it. By adding the additional 330 ohms pull-up to 5 volt the current is reduced by 50%, but should still be enough. It would also be ok to not use my pull-up to 5 volts, but instead use a single 490 ohm pull-up to the 12 volt supply. This would give full current to the led. Your voltage divider would also work, but it involves more parts. The problem is that the sensors are open collector NPN, while the board is looking for PNP style outputs. This is why You need to change the active state and use the switches in parallel, rather than in series. A proper solution would involve connecting the switches to and gates, but then you would need another circuit board with the gates on it. Wired as I propose, the BOB led would be on when the switches are clear and off when any of the switches are near metal. However the circuit won't be fail safe in the event of a broken switch wire.
Kenny
Sorry - I didn't have any details of the Brealout Board.
I would go back to one of my earlier posts - I would think a different sensor, preferably 5 volt PNP, would make life a lot easier, especially when you are all up and running - and all of a sudden, one of your sensors fails. The fewer parts, the easier is life.
Having said that - the BOB is a bit of a *****. The vast majority of sensors pull the signal to 0v. This is what the computer port is looking for. Why invert it.
Thanks Guys for you input,
All seems like lots of trial and error (and lots of smoke,If I stuff it up),so I might give it a miss
Yes ,Jimpinder the BOB is abit of a #?##@,I haven't had much luck with other things on the board as well, and as I have wasted enough time now,I think its going to look real nice sitting next to the other paper weight,the G100.
Another excellent purchase,NOT!!!!
Rather than pull all the switches off and rewire new switches ,I think I will just go and get another BOB,the one I was looking at to start with that handles these switches,
A pitty I was told different prior to purchase?
Anyway, thanks guys for looking into this for me,
Regards
Whatda?
Am I missing something here...
The C23 wiring info indicates how to connect a 12v sensor...
NOTES:
This board has 18 inputs and 16 outputs for a total of 34 I/Os.
1.All inputs and outputs are provided with pull-down resistors.
2. If you need to connect a device that outputs more than 5vdc, you can use a resistor to limit the current.
Use the following resistor values:
10 vdc - 1 MOhm
12 vdc - 1.5 MOhm
24 vdc - 3.9 MOhm.
To use these resistor values your card must be powered with 5vdc. If you are powering your board with a different voltage unexpected results can happen., including damage to the board.
http://cnc4pc.com/Tech_Docs/C23R2WG.pdf
Does this not work?
I'm afraid so. Unless Ohm's law has changed today. I suspect a typo in the documentation.
The optoisolator LTV847 has a 1.4v forward voltage drop. In a 5 volt circuit the total lost voltage across the current limiting resistor is 3.6v. With a 330 ohm resistor already in series and using a 5 volt supply You get 3.6/330 or 11ma current. With a 12 volt supply You get 12-1.4 or 10.6v/11ma = 963 ohms. Since there is already a 330 ohm resistor present You have 963-330 = 633 ohms. I believe that the M is a typo and should be K Ohms. even then, the resistor will not allow for sufficient current transfer through the opto. You want to get at least the same 11ma that the board was designed for. That said a resistor of 633 ohms at 12v is correct. The LTV847 will easity accept 50 ma so a 560 ohm resistor at 12 volts will assure sufficient opto operation albeit at 13ma.
Kenny
Thanks for the explanation! I would have blindly followed the values given in the documentation!
Simon
