Mach Discussion => General Mach Discussion => Topic started by: fristot on May 06, 2008, 01:44:10 PM
I am a newbie in Mach3. I just managed to run some G-Code on my machine. Unfortunately, I do not manage to input (with the keyboard) value in DROs in Mach 3 (v2.63).
For instance, I'd like to set the A diameter (to get a correct feed rate when axis A turns).
I can select the DROs (color changes). But I can't set a value. I stays at 0. Same for all DROs. If the DRO was not 0 before, it turns to 0 when I hit the first digit (whatever it be).
Seems very strange to me. I could not find anything similar reported by other users ?
Config : windows xp / thinkpad X31
Pierre.
Are you pressing the enter key on your keyboard after you have typed in the digits?
Yes, I tried to hit enter : the DRO selection turns off and the color turns back to normal.
When I input a digit (just strike a number key, with the DRO being selected), the DRO value turns to 0 (assuming it was a non zero value at first). Whatever the key I hit, the result is the same : the DRO stays selected and does not change if it was zero - or turns to zero if it was not. Hitting "enter" deselects the DRO and the initial value reappears.
I have v1.83 on my desktop and there, it works fine.
Might be something related to the keygrabber ? But I can't find anything about this software - even how to unistall it ?
Pierre
Make sure the reset button is not flashing when you are trying to make any changes.
They will not change if the machine needs resetting.
The reset button is not flashing.
Still I can't input values.
Pierre.
are you viewing the DROs while in machine coordinates?
I don't understand the question. The DROs values are displayed OK. Only when I try to change them, I can't. I try to change the A rotation diameter, the X,Y Z tool change position (in the setting screen). I don't want to change the DROs of X,Y Z current positions (And this would only change the offset I think - I cannot change anything here either anyway).
Pierre.
You will see a button below the DRO that says Machine Coords. If the RED light is around this button it meansd you are viewing Machine Coordinates in the DROs. You can not change machine coordinates, they are set by your home position. What you can change however is a work offset, if you make sure you are4 not viewing machine coordinates then you can zero or enter any number into the dro that you want and this will be your work offset.
OK. I am not in 'machine coordinate' mode so I should be able to alter these DROs. But I can't.
Same for all DRO's.
Actually I can input values, text.. in the MDI line for instance, or in the config menus.
Everything seems to work perfectly, except changing the DROs values.
Pierre.
please attach your xml and i will see if i can find a problem.
Thanks a lot for the support. Here goes the xml file.
Pierre
Seems to work fine here.
I however dont have a Joystick so possibly that may be causing problems, can you disable the Joystick and see if things work.
I disabled the joystick. Still it does not work.
I just noticed that in fact, when I hit something (numbers..) in an initially non zero DRO, and then I hit enter, the DRO turns and stays to zero. It does change. I just cannot input the numbers I want.
Is there another way to set the A diameter and the change tool positions (for instance in the G-Code)? I imagine it is possible using vb. Maybe I'll have to try that.
Pierre
Pierre - Stop jumping up and down.
In Mach3, you can enter values in the DRO's. You do not need VB's and anything else exotic. If you cannot do it, then you have a fault.
Mine does it, Hood's does it, most other people's will do it.
Lets get back to basics. What is your set up. You have downloaded Mach 3. You are using a thinkpad X3 (is that an IBM machine) running Windows XP. What other bits and pieces have you got on the machine - what machine are you trying to run. Why have you got a joystick attached.
What you should be able to do is - on a DRO that is showing program co-ordinates (not machine co-ordinates) - click on the DRO to locate the cursor, Type in the relevant position, Press return - the DRO should have reverted to it's normal colour and your information should be displayed. If you do not press return but go straight to another DRO (or something else) the first DRO will revert to what it was showing before you started.
You seem to be saying that your computer is not doing this - are you sure you have the correct procedure.
When I read your post again, you are saying that what you want to do is enter a diameter in the A axis - I don't understand this - what DRO are you trying to access. The A axis is linear or rotary - as selected in configuration. The A axis DRO shows either the number of degrees you are moving, or the number of inches. Diameter does not come into it
Similarly with the tool change - have you got anytools entered in the tool table - they must be entered before they will show (I have just tried mine but it will only enter up to 88)
Thanks again.
My config: Laptop IBM Thinkpad X31 + Windows XP pro
Controller on the parallel port (0x3bc) - nanotech IMT901 based + 4 axis machine (PF 600C)
The mach3 driver works fine, mouvements are smooth.
I tryed version 2.63; I just reinstalled v1.83. Same result.
The joystick is a USB standard joystick. I use it to jog. (just a little stange thing : when my home buttons are ON, I no longer can jog with the jostick. I first need to move out of the switches using the arrow on the keyboard)
My A axis is a rotary table (4th axis). I just wan't to set the diameter (in the setting screen 'A diameter' DRO), because the feed rate is not correct otherwise when I launch my G-code. Also I need to change the 'tool change location : X, Y, Y' DROs in the same setting screen.
I understood the normal working of the DRO (the 'enter' key needs be pressed to validate). I know exactly how it should work because it does work on my desktop PC. (for some reasons, I now need to use the laptop instead - which I know is not so good a choice)
I already spend hours on the DRO input problem. This is why I talked about a trick to input values another way; I really need to find somethnig. But obviously I would prefer to really solve the issue (very surprising indeed that I seem to be the only one !)
Just another thing : I launched keygrabber once. Don't really know what it does and how. It seems not to appear anymore.
Pierre.
Keygrabber should only affect things when you have it running, you need to physically start it each time you start Mach or have keygrabber start Mach. To uninstall Keygrabber just delete the files.
I am not long home from work but I will have another look and see if I can find the problem, there is definitely something amiss as just before I left the workshop I did notice that your Y axis home was active but I could see no reason for it to be in that state.
Do you have any custom VB buttons or Brains?
No
>Y axis home button :
it should not be on.
For me, it seems to work. I set X=300 and Y=496, Z=0 for home (the home switches are also limit switches for me). It is more convenient for me to have them in the upper right corner. Therefore this setting.
I still can't input numbers in DRO, even when the machine is not connected to the PC (no limit switch on)
Pierre.
What I am meaning is with your xml I have no switches connected but the Y Home seems to show as activated even though it shopuldnt be. According to your active low setting the pin should Not be seen as active but for some reason it is. I will get Brian to have a look when I see him online.
I also sometimes get the ticker displaying an error regarding VB, cant remember exactly what it said.
You also say you have limits and homes set up using the same pins, in the xml you sent you do not have the limits enabled, only home switches.
Hopefully Brian will be able to shed some light on this, in the mean time you may be able to manually set up a new profile, it would mean entering all the settings again manually rather than just cloning a previous profile but I think it would work.
I tried using MachTurn. I take the profile given at the install. No modification at all. I get exactly the same result as for DROs :
For instance, the DRO "Feed : inches/min" is 6.00 by default.
I click on it -> it turns white.
I hit '1' (need to press shift - key(1) because there is no separate keyboard for numbers on this computer keyboard), the DRO value turns to zero.
If I validate with 'enter', it stays at 0. Otherwise, it turns back to '6.00'.
I tried all keys. Characters yield no DRO change. Numbers, '-', '+', yield '0'. Just depressing 'Alt' also yields '0' but NOT 'ctrl' or 'shift' alone.
There seems to be nothing special in the config of this PC (XP was just installed, not many other soft : office, CAD, antivirus and mach.
Really strange. I'll try to connect an external keyboard when I can. Otherwise, I have no idea.
Pierre.
I just found something :
On the thinkpad keyboard (french keyboard), if I deypress a 'shift'+ 'Num/Defil' key, the keys 'J K L, U I O, 7 8 9' are considered like '1 2 3, 4 5 6, 7 8 9' of the numerical keyboard - right part of a 102 keys keyboard (sorry - I don't know the name of this right part of a keyboard in english). And with these keys, IT WORKS : I can input values in DROs !!!
This solves my problem. But obviously, it would be more convenient to be able to use the usual numeric keys..
If it is not clear, I'll make a picture of the keyboard to show what works and what does not.
Anyway, thanks a lot for help. I really appreciate.
Pierre.
OK thats good to know you found the problem, I was just about to suggest you go to the operator menu and clcik the Auto Calculator option to see if that works. Give it a go anyway and you might like it.
-> YES !, I like it. ;D
Thanks again.
Pierre.
