Mach Discussion => General Mach Discussion => Topic started by: PJEnge on April 11, 2008, 02:33:36 PM
Hello Everyone,
Well after spending 3 days searching for what was causing Mach Version 2.61 to act crazy after having worked great for months, someone recommended that I redo the config in a new file.
I did that and now everything works, except I cannot find the box to check for reversing the A axis stepper motor direction that is slaved to the Y axis... the motors are going in opposite directions on the gantry...
I went through the manual and it says to goto config/ motor reversals...BUT that tab is not listed under my config options.
Any help will be GREATLY APPRECIATED!!!
Best Regards,
Preston pulling out my hair >:(
Config menu > Homing/Limits
Monte
THANK YOU MONTE!!!!!!!!
Best Regards,
Preston
Monte
