Mach Discussion => General Mach Discussion => Topic started by: BosniaCNC on April 01, 2008, 05:29:20 PM
????? Where is problem?????????????
S.Markovic
What makes this happen? does it always happen or just with that code? Is it just when you load the code or is it after the code has been running a while?
Any other details you can give may help.
Now, Mach3 is OK !
I will tested again from Mach1 to Mach3.
Thank on your post,
S.Markovic
