Mach Discussion => General Mach Discussion => Topic started by: flyrod on May 04, 2006, 11:46:30 PM
Is there a way I can set up the space bar on the keyboard as an Estop in Mach3?
Rod
Yes use the key grabber.exe found in the Mach folder
Bear in mind you really should have a proper e-stop chain on your machine. This should act 1st before any s/w e-stop.
Wayne...
