Mach Discussion => Mach Screens => Works in progress => Topic started by: chucky on February 27, 2008, 05:07:59 PM
Working on this simple screen for me. Started with graphic buttons but I did not want to make a button for each one. All the led�s that don�t work with the button will flash with e-stop.
Edit pic update
I like that screen, please send me a copy of the finished set. :)
Graham.
Thanks Graham
I have it so if you start from the left of the screen and work to the right with a straightforward g-code file you should be up and running in no time.
Most EXCELLENT work!!!
scott
Good Job Chucky,
If you post it, I may use this one on the Hurco I'm retrofitting right now.
here is screen 2 for now
Edit
I Like it, Very clean looking!
THX
screen 6
Edit
Settings and offsets
When might you release this so the pubic can play with it.. :o
Look like it might work well for a touch screen too...
This week - need to add pan and zoom buttons
MDI screen
These screens just get better, I like clear, clean looking, informative screens, keep up the good work.
I am looking forward to trying them.
Graham.
thx
scope and code screen
wizard screen
Fantastic. I like the clean look. The colors are easy on the eyes and very legible.
Very good Chucky. Should be nice for a touch screen.
Thanks guys
Just hit any bottom button a second time and the MPG will pop out.
If you need to adjust the other doodads on the MPG just pull it out further and there they are.
Here is my skin ready to try.
Let me know if there are any problems or suggestions.
Hmmm... Maybe I am missing something but looks like the background image is missing. Did I do something wrong?
You need to put the chuck’s folder with all of the images in it to the Bitmaps folder and copy the chuck’s.set file to the mach3 folder and let me know.
also
Thanks chucky, I forgot you had to copy images to the bitmap folder. I will give that a try!
Looks good. Had the same problem as bcromwell at first, but that was an error with winzip extraction. Thanks for your time making the set.
wow! that screen is wow, simply wow, simple ans efficient!
Thanks guys
Here is an updated set that gives the led’s a lot more logic.
What do you think about these buttons?
Looks Great, I like it.
I did get it working btw, Thanks!
The set I will post tomorrow will have this screen that I will use a lot.
It’s just a simple thing to remember and go to 9 x y coordinates and 2 z coordinates.
