Mach Discussion => General Mach Discussion => Topic started by: KBattenbough on February 23, 2008, 09:03:39 AM
Hi Guys
Im new to this forum, and would like to hear your opinions on an idea i have. Whilst admiring a haas tl2 lathe and thinking how much i would like one, it occured to me that for the price of one i might be able to get my manual lathe reground, and retrofitted to cnc, and mach3. The lathe will be used for gunsmithing work, and like the fact that it has a short headstock so that i can get both ends of a barrel bore clocked, and add coolant through the bore whilst chambering. I would like to be able to clock a barrel blank in, and let the cnc thread, counter bore, then bore the chamber undersize, and finaly finish off the chamber manualy with the tailstock. Also it would be nice to profile a barrel blank between centers. I know as a rule converting a manual to cnc is going the long way around, but i realy do like this lathe. I know its going to be expensive too, but want to hear your thoughts on it, and tell me im not mad ;D
Its a cazeneuve 590 by the way, and hopefully the pics will attach.
Kev
(http://i62.photobucket.com/albums/h108/KBattenbough/caz%20590%20hby/IMG_0661.jpg)
(http://i62.photobucket.com/albums/h108/KBattenbough/caz%20590%20hby/ktcaz029.jpg)
(http://i62.photobucket.com/albums/h108/KBattenbough/caz%20590%20hby/ktcaz027.jpg)
Compared to haas it will not cost that much to retrofit and is very doable. Here are videos of a person that did the same thing you want:
http://www.youtube.com/profile_videos?user=westchagnon
shouldnt be any problem at all, I retrofitted my 14x40 enco with ball screws and servo motors a few months ago and its working perfectly, I am turning and threading bbls with it no problem. I can cut , face and thread both ends of 65-70 suppressor tubes in an 8 hour shift. I have been very happy with the brakout board and spindle encoder from cnc4pc , pendant is very nice also. Only thing left to do on mine is finish up the 8 station auto tool turret.
I would say go for it , very rewarding outcome
For your input guys, it puts my mind at rest, and gives me lots to think about now. 8)
Regards
Kev
All you honestly need is two stepper motors and drivers. ArcEuroTrade in the UK has some large steppers that would do it.
Don't try to get all singing and all dancing straight away. If you drive the cross slide and the main leadscrew that is all you need.
The advantage is the LATHE is the same, it is the one you are used to, so any little problems will be easy to deal with.
Mach 3 provides many configurations for backlash and other little things to get the lathe set up correctly.
All I did with my lathe was take off the operating wheel, and substitute a drive via a tooth belt.
Don't underestimate how much power it takes to run the Z axis, the saddle. My experience is that it might be three to four times the amount needed to power the cross slide, the X axis. A decent ballscrew will help a lot if you can afford it or find one used from a larger CNC machine as I did. I see Jim's lathe here has a large reduction on the Z axis, this helps a lot but reduces the rapid speed down that amount too. So, if you use a large motor on the X axis along with the Z axis, then the power supply will match better, if you go with a smaller one for the X axis then you need to be careful that the higher voltage power supply that the Z axis motor needs is not too high for the X axis.
DaveA.
For the sound advice guys. When the time comes for this retrofit, im going to let the experts do it, and look for somebody who can do the full works, grinding, repaint, ballsrews, etc..., there will be no expense spared on this, but i think i will end up with something along the lines of a haas tl2, but perhaps more versatile, and i think certainly more rigid. and probably less the cost of a haas.
Kev
Ok guys
A little update, I have had a quote to do the above work, but in the price was the heidenhain conversational controller, and they came back with a rough guess of £30k :o. Now i am not afraid to spend some money on this, but that is just rediculas!. So my thinking is i would like to still get a complete regrind of the ways, and turcite added, so that i know everything is good from the start, and have a go retrofitting it myself, or have somebody, whos done it before do it. Please bare with me and the following stupid Qs, but i am old school and a total newby when it comes to cnc, but i want to get into it and learn it. Can you guys tell me EVERYTHING that i will need to convert this machine to cnc? and if possilbe give a brief explanation of what things are? from what i can gather i will need mach turn for the controler,ballscrews, servo motors to drive them, dro? glass scales? for mach to read what the servos are doing? and what about the spindle motor? does it changed to a vfd, or servo motor? i dont know? .When i am ready to go for this i will have a budget of £15k, so if you were in my shoes, what route would you go.
All advice appriciated.
Kevin
Kevin -
The first thing is you have to decide what you want at the end of it. To me 15K is a lot of money and several of my CBC friends have got rid of CNC machinee centres for a lot less than that. I don't have the space, unfortunately.What are you seeking to do with the machine. You have talked about the firearms work etc, but that doesn't seem all that much (to me), unless you are a registered dealer.
A CNC machine has two advantages. One is speed - but in actual fact if you add all the time it takes to program the thing, for a one off you could be better doing it manually. Having said that, I prefer to do the program in the comfort of my "office" (front room) and then transfer it to my workshop computer to run it, rather than be bunched up over the lathe all the time. The second is repeatability. If you are machining a number of the same parts, then CNC is the way to go. I think there may be a third - in that programing is easier to me that machining. I can program the machine, test the program, and then be confident the machine will cut it. Doing it manually, I could make a mess and spoil it.
My lathe is much faster now than it used to be, particularly on the rapid non-cutting moves (and it doesn't waste time thinking about it)
Cutting is much the same, you have to use the same cutting speeds anyway. To achieve this, I have not altered my balls screws, or anything, I have just installed stepper motors. Mine could be wired three different ways - see an earlier post - now thety are wired in parrallel, with the Geckos, they fly.
If your lathe is in reasonable condition then a regrind might be all that it needs. How is your backlash. Mine is a lot, but Mach 3 copes very admirably with it. Cutting ball shapes you cannot see the join.
If it were me, I would have the machine reground, and delivered back. Quite frankly, if you are a reasonable engineer, you can do the rest yourself.
If you are in UK - (you talk in £'s) - then purchase a motor from Arc Euro Trade. They sell a 650Ncm motor for £50. This is 3 times the power I use (my lathe is a large Warco combined lathe/mill - and I use the 220Ncm). They should drive anything and your machine looks like my friends Harrisson (of a similar size anyway). I would buy one motor for the time being, and see it's capabilities. Unfortunately I do not know of any simple way of calculating what power you will need, nobody on this forum has come up with any ideas.
To power this motor you need a stepper driver. Buy single units - do not be tempted to buy a three in one - if one breaks, it's easier to fix. If I were you I would buy Gecko drives - American - very good and the standard Gecko has the voltage and current capabilities to drive the 650 motor. All you have to do is fit them to your lathe. My photograph on the earlier post shows the one fitted to the lead screw. Yes, I have used a toothed belt drive, these are cheap, they transmit the power without slipping, and the range of sizes is enormous. The advantage is - if you fit your motor - say with a 1 to 1 drive - and you find you need a bit more power - then fit different cogs and you can scale up your power ratio (for a loss of speed I admit) - but you will be able to find the ratio you are comfortable with that gives you enough power - with a speed you can live with. Merely remove your handwheel, fit a toothed cog, mount the motor in a suitable place and then buy the correct sized belt. My belts are 9mm wide, 5mm pitch. On your machine I would use the next size up. These should be available from any bearing supplier - and haggle the price - they give up to 90% discount - I kid you not. I WILL fit covers on them sooner or later (probably later knowing me).
I don't have a problem with speed on a lathe. These lads that have aircraft carrier flight decks for their router tables like the thing to travel at the speed of light. I got mine up to 40 inches per minute ( with a 3 to 1 reduction) so with less than 20 ins travel, I could be up and down in no time. I have cut the speed to 20 ins so that I trade accuracy (less chance of missed steps) for speed.
If your leadscrew is in reasonable condition, then don't change it, unless you really want to - but I would try with it at first and see the results. As you gain confidence, you will decide how far you want to go. For the sake of simplicity I would use the same motor on the cross-slide - which is why I said only buy one to start with. A 650 motor should certainly cope with the cross-slide - and you can probably use a higher gear if you wanted, although again - speed isn't everything. If the motor is too small for your leadscrew, use it on your cross-slide. If it's OK then but another one.
For £500 you should be able to buy 2 motors, Gecko drives, gearing and belts to get started. The only other thing you will need is a power unit. For this, you have little option but to buy a professional power unit. The motors are rated at 5 volts - steppers are "over driven" so a 30 volt power unit able to give about 20 amps should do the job. This may be expensive, but we are still well short of the 15K
Don't get the idea that these "machine shops" can do any better at retrofitting a lathe than you can. All they do is cover it up so you can't see what they have done - and charge you a hell of a price for it. You can buy ALL the parts for £1000. Yes you could spend a lot more I am sure, and other people will probably advise you to buy something different. Certainly for £2000 you can get the best - certainly to do a two axis lathe - so where does the other 28K come in.
Have a try - very little will be wasted and you will gain a lot of knowledge, even if, in the end, someone does most of the work for you.
Send it up to me and the 15K and I will get you sorted out ;)
Seriously though, £15,000 would buy you a decent CNC Lathe, in fact probably half that. Big advantages is they will have toolchangers, ballscrews etc. You could then sell the old motors drives etc on eBay and fit AC Servos, unlike Jim I think speed is definitely important, with tool changes you will want serious rapids, my Lathe does 3.3M/min at the moment but once the SmoothStepper has the threading sorted it will be getting fitted to the Lathe and my Rapids could be as much as 20M/min, but I think 10 will be what I settle on.
Just my opinion but I was thinking along the same lines as you in that I was going to retrofit one of my manual lathes, glad I didnt :)
So is the differance between using stepper motors and ac servo motors just about speed? or power?
Kev
AC Servos have Speed, also have a continuous rated torque, that torque is from zero to full rated RPM, acelleration is also extremely rapid with servos. Servos also have encoders which close the loop between drive and motor.
Big disadvantage with AC Servos is the cost.
If not in a hurry steppers can be used, they do lose torque as speed increases and can lose position if the going gets tough, HOWEVER with properly sized steppers the torque will not be an issue and they wont loose steps because they have been sized as to have enough torque at all forseable conditions.
Stepers are very cheap when compared to AC Servos.
For big machines steppers are not a viable option because you will have to trade far too much speed and acelleration for the sake of accuracy.
Just my opinions based on my stepper Bridgeport CNC and my AC Servo Computurn Lathe.
BTW Kev are you in the UK, If so where about? I am in Scotland as can be seen to the left :)
Yes im from the UK, i live near Bolton, Lancashire however im currently workng in Iraq, which is why this project is a way off, timewise. I have seen your lathe on youtube and it looks the same size as my cazeneuve, i was tempted to buy it when Budget machinary had it. ;D
Well if your lathe is anywhere near the size of the Computurn you definitely dont want steppers, unless that is you want to start it machining before you leave for Iraq, then it should be finished as you arrive home :D
Thanks for the advice
Im just reading your thread (just got a lathe to retrofit). Very interesting! ;D
Yes that was a long learning curve for me, and expensive when I was trying to run these great big DC motors from the small drives, smoke was a common occurrence :D I have learned a lot from doing the lathe and I am now applying that knowledge to my latest retrofit which is a Beaver Mill, twice the machine that the Bridgeport is :)
Thanks RICH
Ive certainley got lots to think about, part of me is saying DO IT anyway, if only for the experiance.
Kev
Kev
Its quite hard to tell a size of a lathe from pics but often a good way is the size of the chuck in relation to the rest of the machine, any idea what size the chuck is on your cazeneuve?
It has a 12 inch chuck in the pics, swing is 595mm, and approx 40 inches between centres. Heres a pic ive lifted off the web to give an idea of its size.
Hopefully pic will attach.
Kev
Well that pic makes it look way smaller than the Computurn but I have been looking on the net as well and it seems of similar size. Actually it swings a bit more than mine, the computurn is 520mm. The Computurn is basically a TUR50 which Churchill took the basic bed and headstock and added the CNC parts. The Computurn is about 3 tonne, from what I have found so far yours weighs in around 2 tonne. The saddle on mine though will be adding a lot to the weight of my lathe.
Now that I know the size then I can safely say no way you want steppers and you will definitely need ballscrews, best option for you in my opinion is to keep that nice machine as a manual and get a ready made CNC to convert if need be, that is presuming you have the room.
Having seen pictures - yes - servo motors are the way to go.
I must admit, I agree with Hood when I said a lot of my CNC friends have disposed of machines for a lot less than 15K.
If I had the space and that kind of money, I think a purpose built CNC machine would be the way to go.
The thing is, they were designed from the bottom up as a CNC machine. The motor etc will be all sized up, the power supply fitted, so it must save a lot of work. And a toolchanger !!! ::)
Thanks for your help guys much appriciated.
I know it would be easier and cheaper to buy a used cnc lathe, but i like the fact that the caz has a short headstock, like i said in my first post, i,ll want to get to the rear of the spindle to adjust a spider while clocking a barrel in, also the caz has a hydraulic varispeed, with a high and a low gear. The more i look into retrofitting this the easier it looks to do. As for a toolchanger, i like what hood has on his, and will want something similar, i think 'duplimatic' make one, aswell as others ive seen.
Go for it, much more fun doing it yourself ::)
Phil_H
How accurate is the Caz at the moment?
For a Lathe that size you are going to need big ballscrews so they are not going to come cheap, as an example the Z on my Computurn is 40mm Dia. Jim mentioned earlier about using the standard leadscrew and using comp however on a lathe this size you are going to need all the help you can get and leadscrews would just mean you have to go quite a lot bigger on the motors so its a false economy in my opinion.
Panaceabeachbum has a duplomatic on his lathe and it seems quite a nice turret although maybe it would be better with a servo on it rather than the normal motor.
Because of my limited time when i was home last i did not get a chance to power it up, however the guy i purchased it off said it will hold 1 thou over 8 inches.
http://www.automotion.co.uk/pdf/L1396-roller-pinion-system.pdf
Just to throw something out there, has anybody tried the above system instead of ballscrews?
Kev
1 thou over 8inch is not that bad for an old lathe, dont think I would bother getting it reground unless you are needing tighter tolerences. The Computurn is dead nuts as far as I can measure but then again its probably got less than 100 hours on it in total.
I was looking at a similar rack a while back but dont know how good it is in reality, the stuff I was looking at was supposed to be as accurate as a ground ballscrew and with similar amounts of backlash, ie minimal. I dont know how much it was and I dont have the link here but I should have it at home, will look and post it if I do.
http://www.youtube.com/watch?v=vPPhwoe2QMU&feature=related
This looks very interesting!!
Kev
Yes thats the stuff I was meaning, looks good but dont know the cost and whether it is as good as it seems.
Ive just been informed that the rack and pinion is only used for grinding applications, oh well :(
Who informed you of that? Cant really remember what the Nexen site said, but from memory it seemed they were certainly using it for much more than grinders. Might not be strong enough for a big lathe though.
Ignore my last statement :-[, I got my wires crossed, ive so much going on right now, i mixed things up, sorry :-[.
However like you say hood, it dosent look strong enough for a big lathe.
Kev
