Mach Discussion => General Mach Discussion => Topic started by: skipper on February 19, 2008, 12:52:26 PM
Hi Folks,
I am using SolidCAM as my CAM program. When setting up my part, it ask for a controller type. They list a bunch but the default is FANUC. Is this the one that I sould be selecting to use with Mach3?
I am assuming FANUC is a contorller like Mach3 correct? I asked this question in the SolidCAM forum of CNCzone but got no response.
Skipper
I think the Fanuc one works ok but there was one on the Yahoo group a while back, I have attached it here
Hi, Skipper
Yes, There called Post's, Mach3 uses Fanuc/Standard G-code as do many machine controller's, It may not support special G/M-code's though.
Fanuc Post may get you going, Post some G-code with it and do some air cuts, But most Cad/Cam Mfgr.'s have a Mach3 Post these day's.
If it won't load in Mach3, In the G-code window it will stop on the White line and at the bottom Status: Line and should show the problem.
Hope this Helps, Chip
I am using SolidCAM and I did not see Mach3 as a controller option. I also joined the Mach3 Yahoo group, my membership is pending. Hood thanks for the post files, I guess I need to find out how to load them into SolidCAM. Is that what I am supposed to do?
skipper
skipper
just unzip them to the C:\Program Files\SolidCAM*****\Gpptool folder , then go to the "options" for SolidCAM (cant remember the actual name) then choose it as your default controller.
Hello,
Does anyone has a Pre and Post Processor for Solidcam using MILL_&_TURN operation
as a machine_type that produce G-Code for Mach3?
The Mach3.mac and Mach3.gpp files that is out there are for MILLING operation only.
Maybe some sharp people out there can help me modified the Mach3.mac and Mach3.gpp files
to work in MILL_&_TURN operation. (The mac_axes is XZC)
I have tried to learn the gpptool-example already but I still don't have
a clue how to modify the files. Sorry, I am not a programmer.
I would appreciate with any help.
Hi everyone,
I'm looking for a post processor for solidcam,
I've a mill-turn (4 axes)
Any Help will be very very appreciated ! :)
Hi everyone,
As already said the standard Fanuc post should work fine. If you still have problems then perhaps contact SolidCAM support and ask their advice.
I've searched for days for a turn PP but couldn't find a proper one. Does anyone have any?
