Mach Discussion => VB and the development of wizards => Topic started by: DennisCNC on January 30, 2008, 09:25:53 PM
Is there any code examples for saving DRO values in a .txt file that can opened later for review? For instance GetDRO x and y (encoder values) and save to a .txt file when a input is activated.
Ok, i got curious...
i took this: http://www.vbforums.com/archive/index.php/t-342619.html
and added a getoemdro
and got:
Dim sFileText As String
Dim iFileNo As Integer
iFileNo = FreeFile
'open the file for writing
Open "C:\Test.txt" For Output As #iFileNo
'please note, if this file already exists it will be overwritten!
xd00d=getoemdro (800)
yd00d=getoemdro (801)
zd00d=getoemdro (802)
'write some example text to the file
Print #iFileNo, "X= ", xd00d
Print #iFileNo, "Y= ", yd00d
Print #iFileNo, "Z= ", zd00d
'close the file (if you dont do this, you wont be able to open it again!)
Close #iFileNo
and then when you view that file as spec'd in the code, it has the dro info at the moment the code was ran (although if the axis was in motion, i dont think it would be accurate, that takes a dll).
-Nick
Interesting perhaps if you did and experiment and ran that in the Macro pump, it would update at least 40 times per second.........
just a thought.
Scott
Nick,
Thank you very much for the code example!
Also a big Thank you to Scott for helping all the learners here with your time and examples!
Wow!
Your welcome!
scott
Few more question on this VB stuff. I have this code working and dong exactly what I want in VB software:
Dim myvar As String
Dim place As String
Private Sub Command1_Click()
iFileNo = FreeFile
myvar = InputBox("Enter place")
place = "c:\" + myvar + ".txt"
Open place For Output As #iFileNo
End Sub
Private Sub Command2_Click()
xd00d = 123
yd00d = 123
End Sub
Private Sub Command3_Click()
Close #iFileNo
End Sub
When you click the first button a window comes up to type in File name. Then the second button saves "123" in a vertical column as many times as you click it. The last button Closes the file.
Now I moved this code to Mach the first button and the last button work fine but the button to save the coordinates from GetOEMDro (800) and (801) instead of the the "123" value does not work.
I think it's because the Open command is a private deal. How do I make the second button work?
What I did was made one button and put this code in it:
Dim myvar As String
Dim place As String
iFileNo = FreeFile
For the second button this part of the code:
xd00d = getoemdro (800)
yd00d = getoemdro (801)
Last button:
Close #iFileNo
Hi DennisCNC - If I understand you're explanation correctly, your problem is scope. In the first file your 4 variables are global with respect to your subs (i.e. "visible" to the subs). When you put your code in Mach buttons however the scope of one button does not extend to another. Your 4 variables are "invisible" outside of the first button. (are you getting a "bad file number" error on button 2? Actually I suspect that your 3rd button isn't actually doing anything either but the flaky VB in Mach is not reporting the error - the file is being opened AND closed by the script in button one - (explicitly opened by your "open" code and implicitly closed by going out of VB scope at the end of file).
Incidentally have you taken a look at the plugin download section - Brian has a thing there called jcode - a jog to gcode tool.
Ian
I kind of figured that variables don't go from one button to the next. I think I need to put this in a macro and have it run a part of the code when a button is pressed, something like GetUserButton() or GetUserLed()?
I looked at the jog to gcode plugin but you need to jog for it to take the dro value and save it, I need to save the encoder dro's that are on setting tab.
