Mach Discussion => General Mach Discussion => Topic started by: sooperdrave on January 14, 2008, 07:12:02 AM
my machine is a 5 axis machine with x, y, z, and a axis' my a axis is a rotating table. it wont reference. when i try the status line says: "requested home axis home switch is active. please fix, then home." anyone know what this means or how to fix it?
thanks,
dave
edit: also the homin g switch under the table is on and not turning off, wondering if the switch is junk?
Hi, Dave
Check the switch out, Then in ports & pins, inputs, You may need to change the "Active Low" setting state for the A axis.
Chip
hi chip thanks for helping! i tried turning changing active low. when i did the light on the switch and in diagnostics turned off. then i tried to reference and it still didnt work so i put the settings back to what they were. i think the switch is just junk.
thanks
dave
