Third party software and hardware support forums. => Sieg Machines => Topic started by: chrisjh on January 11, 2008, 11:57:52 PM
Hi All Syil X3 Mill Users,
Syil X3 Mills are Seig X3 Mills converted to cnc.
At the attachment below you will find the procedure that I used to calibrate the spindle speed of my Syil converted X3 Mill. The procedure calibrates the speed requested by Mach3 to the actual speed of the machine.
I was always annoyed that I could never attain the maximum 3400 rpm under Mach3 control. The low end wasn't too bad as delivered but the top end was miles out.
I have now adjusted my machine following this procedure and I am now happy. Of course the calibration is for speed settings with no overrides.
Hope this helps for those who like myself wondered how to do this for 12 months.
I was lucky that my machine front panel speed display was quite accurate when checked with my laser optical tacho so I did not need to adjust this. If any one knows how to calibrate the front panel rpm readout, please let me know and I will amend the procedure below so others can benefit.
Kind Regards
Chrisjh
Thank you for posting this info, I will surely benifit.
