Mach Discussion => General Mach Discussion => Topic started by: olf20 on January 07, 2008, 04:55:21 PM
Hi all!
I downloaded the current lock down release R3.01. When trying to install, the install will stop and give me this error. "Can not continue install because file "dxfreader.ocx" can not be found.
I double checked my Mach3 folder and this file is present. I tried the install / upgrade several times but the same error occurs.
I'm installing this in the same folder / drive that I have always used for prior upgrades.
Any help will be appreciated!
Thanks olf20
Not tried it myself but will do so in a few mins, did you try re downloading it from the site just in case you got a corrupt download?
olf20
where are you getting 3.01 from? I only see 3.00 on the downloads page.
Sorry typo, it is 3.00. I just redownloaded the lockdown version. Tried to reinstall but same error.
Thanks olf20
Strange, i have just installed 3 to try again and it works fine.
I will try again. Thanks for the help!!
olf20
