General CNC Chat => Show"N"Tell ( Your Machines) => Topic started by: ftomazz on January 04, 2008, 03:48:42 PM
Hi.
This is my newest work, and also the most demanding work that I ever done.
It is a 3 axis machine to cut large blocks of polyurethane with strips of wood. My client will use this machine primary to make surf blanks.
Some facts: around 30 rollers, 7Kw including vacuum pump and cleaner.
It is tested and working fine. We are only doing a cage around all the machine to maintain a safety perimeter.
It was all designed in my workshop, in south Portugal.
I am accepting orders ;)
Pictures...
Good looking machine. :)
GOOD looking job Filipe.
What are you using for a cutting blade ? (or is that proprietary ?)
It doesn't look like a regular bandsaw type.
Again, FINE WORK,
RC
The machines uses an abrasive wire. It passes through the material to cut at 250Km/h.
It have 3 of this wires, one one the exis that is shown on the first picture (horizontal) and the other two on the moving parts that are vertical.
Filipe
EXCELLENT !
Thanks Filipe !
RC
A video showing it working would be great. You could add it here, http://www.youtube.com/groups_videos?name=artsoft and stream it into this thread.
