Mach Discussion => General Mach Discussion => Topic started by: cliveastro on December 13, 2007, 03:40:30 PM
Hi
This is my first CNC project and I want to use mach 3 to run my x 2 mill, I have built my own controller box keling stepper motors and drivers.
My problem is I cant get the motors to run.
I switch on, the motors energise as I cant turn them.
I have set up the motors correctly as per the video tutorial for setup and trouble shooting.
I had a charge safety pump (cnc4pc) but I have disconnected it.
I have no e stop/limit signals on the diagnostics page.
I have checked my wiring about ten times.
My thoughts are that either the breakout board is not working (cnc4pc - C10) or my laptop controlling it is not working properly.
Another thought is the breakout board is too close to the psu.
Can anyone help please.
Clive
Is your port enabled under ports and pins? Is the port address correct?
To test the port go to config - ports & pins - Input signals - automated setup of inputs and trigger the inputs
KTM
Port is enabled and the port address is correct.
I understand the automated port setup but how do you mean trigger the inputs,
I really am a complete novice.
Thanks so far.
Clive
All you have to do is select the input you would like to set up from the drop down box eg: x limit switch ++ click on autoset and then press the limit.
KTM
I have done that the limits work, but the motors dont.
Do you have power on the step and direction terminals and is the polarity correct?
If so check the pulse train from Mach with an oscilloscope
KTM
I have 5v power on step and direction and the polarity is correct.
Am I meant to see anything in the "Output signals current state" in the diagnostics window because I dont.
Also I only see 2 green leds (5 7)in the port current state.
clive
Post your xml (mill.xml in the Mach3 folder)
KTM
I dont seem to be able to send it as an attachment. Is there another way?
Clive
I have sent you my e-mail address
Hey Clive
Any luck on activating the output?
KTM
Hi Steve
Just about ready to start trying things.
I will need to go and buy a relay to test with or could I use an led?
I am going to try another computer first I never really trust laptops plus they cost more to fix.
I'll let you know.
Apart from one motor to test with, I finished assembling my mill this morning, only one mod to make, but its useable.
So its not all gloom and doom.
Clive
You could just use a LED in series with a 220 ohm resistor for 5V
KTM
I have swapped computers with new software and I now get 8 leds lit in port1 pin state.
I will see if I can find a resistor and led.
Clive
The forum will only accept an attachment once so if a file by that name has already been posted it wont let you attach it again. The way round this is to rename your xml before you attach it.
Steve
I have got hold of an oscilloscope (im not a good driver) however I get square waves out of pins 2,3,4,5,6 and 7.
Where to next?
Thanks Hood, noted.
Thats great ! your break out board is working.
Now check your power supply - maybe the stepper drives are pulling more current than it can supply.
Connect only one motor with no load.
KTM
I have 2 x 280oz in and 1 x 425oz in motors with a 24volt 8.3 amp psu.
My tests were with only motor however I have just remembered I have loaded new software and I havent set the motors up.
I have set the motors to 262.5 mm/min and 0.5 seconds.
I have not changed the psu settings but the stepper drivers are getting 24.2volts.
I have cnc4pc c10 breakout board and I have 5v on the enable line does anyone know if I need to set up anything in mach3? There does not appear to be a pin number to set it to?
The 5V usually goes via the charge pump relay to the enable signal. This is to prevent the outputs from activating when Mach is not open.
KTM
But I still cant get the motor to turn!
Regarding the square waves - What is the amplitude and frequency - are they only active when you run the g-code.
you can also run the motors from the manual screen - press "tab" on your keyboard.
Try adjusting your feedrate - maybe it is far too slow(unlikely)
KTM
Not having measured the amplitude and frequency I dont know, they are only there when I run G code and do start and stop. I did notice that it looked like 3 traces running in parallel, but I am not an accomplished oscilloscope driver.
I have gone back to basics, I have stripped a stepper driver out of the box, I have stripped the cable off of a motor, I have stripped the breakout board out of the box, completely rewired them and I will try it on a bench power supply tommorow.
Now I am going to have nice meal and a glass of wine.
Thanks very much for your help. I am sure we will turn over the correct stone in the morning.
My wife thinks I am a bit grumpy at the moment cant think why.
Clive
