Mach Discussion => General Mach Discussion => Topic started by: mikemill on December 07, 2007, 05:14:32 AM
Hi David
I see you have retro fitted a Starturn lathe, did you use a VFD to drive your spindle?
I am trying to retro fit an Orac, but having problems getting the spindle to turn via a VFD,
Can you offer any advice?
Mike
What kind of problems?
to start with go to Config - Ports and pins - Spindle setup
KTM
Hi David
Thanks for reply, I had an old VFD that came with the machine, so gave up on it and found a new one on ebay.
After playing with a few settings got Mach to contol spindle, at last
What sort of stuff do you make on you machine?
Regards
Mike
