Third party software and hardware support forums. => Newfangled Solutions Mach3 Wizards => Topic started by: Bloy on April 15, 2006, 09:25:01 AM
Rectangular wizard cuts conventionally when asking for climb of inside rectangle.
Am I missing some setting? I ask for an inside rectangle, set it to climb, but it always cuts conventionally.
John Prentiss brought this up in the Yahoo group but apparently it got lost in all the posts.
Is this a real bug or is there something else in Mach3 to have the climb selection function properly?
John (bloy)
Okay I will have a look at it ;D If it is a bug i will have it fixed in a few hours..
Hi Brian,
...just a follow-up.
Did you find anything in the inside rectangular climb-cut ?
Many Thanks,
John(bloy)
I am looking at it now... I was in the middle of Gerber importing code for LCam Pro, but I now have that all working and will start in on the wizard set.
Thank you
Brian
It is fixed and off to Art to be added into the release
Thank you
Brian
Many MORE Thanks, Brain!
