Mach Discussion => General Mach Discussion => Topic started by: vmax549 on November 07, 2007, 06:43:21 PM
I have been working up ideas and code for a CMM page for mach. I need to know if you have any special things you would like to see MACH do as a CMM type machine.( Coordinate measurement machine).
It could do things like probe a hole and set center of circle and give you the diameter.
G68 CR based on the use of a probe to set a vise, or between the COC of two holes, or from any axis plane ,etc
Length between two points and a return to center .
Just need some more input.(;-) TP
It all sounds good to me. A tool length measuring option would be nice I think. A calibration routine would be as well.
Brett if you give me a list of EVERYTHING you could even imagine you would want I will work on it. I already have a LARGE collection of G31 macros running to do daily work ,just need to clean them up and write a maunal . After using them daily it is hard to image working without them.
Examples: The auto tool setting page allows you to check your tooling against a master or gauge tool and sets the tool up in the tool table for you. So when you begin a program you would set each of your tools needed for the job with the ATS and insure your tool table matches your tooling. Just have to remember short tool, long tool so you do not run out of Z travel for offsetting(;-)
CALPRB Calibrate the probe against a known diameter at the intended probing speed to ensure its accuracy. Then update the probe tip offset value in settings.
COC with diameter Goes to the center of the hole and reports the hole diameter. Great for finding out what diam a hole pattern is
CRG31 Auto sets the Coordinate rotation on an axis, allows quick setups of the vise,part or fixture for a program run
CR,COC Sets the CR from the center of two holes. USED mainy on fixture setups to rotate the program to the fixture. Once a fixture is made we set it up to machine and then bore two holes along a plane. Then all you have to do to align the fixture is do a COC in both holes and rotate the program to the fixture.
COSKW Find the center of a shaft to cut a keyway
COSS Find the center of the end of a stub shaft
CoX+ Find the center of two edges in the X+ axis and return to center and report distance
ETC,ETC
Hi Terry,
Is this page going to be dedicated to all different kinds of probing? I.e. array and the one Stirling is working on as well as the different probing wizards and the 3d plugin? Can you give us an idea of how it's going to work?
Push a button type and get a function type of screen?
Mike
MIke in my world, 2.5d milling these functions are called up from G&M codes. So first we get the functions transfered over to the MACH system of things(most are already) Then we create either PAGES or WIZARDS to suit what is needed. That way they can be used as programs items, or used in the converstional method such as wizards or pages.
I have left the idea with RON at NFW but don't know if he is going to take on any new projects.
It can be whatever anybody needs it to be NOT JUST FOR MILLING. I like your idea for a boundary survey to set up a 3d probing routine. MAKES a lot of sense to not waste time probing empty space.
We also need to work on a process that lets users process a 3d points file to Gcode WITHOUT another outside program. I have done small projects with success. A probed copy of the object came out machined looking just like the object from a 2.5d/3d combination perspective.
It really is two different worlds we are talking about . There is the CMM function of measurements and functions and creating CNC programs from vectored dimensions from the basic 4 axis
AND the 2.5/3d Shape profiling that deals with outlines and 3d surfaces. It can include all 4 basic axis as well
Hi,Terry
I asked this question sometime back, Example, A windshield laid flat on a water jet cutter table..
Is there a way Mach3 can follow a X,Y path, set to pick-up Z value (set to probe at X Y move distance say .250) and incorporate it into a new file with X Y Z moves.
Need to trim off some excess edges, on some (one off) curved shapes 2 x 4 feet, plasma, Water-jet ?.
Any Thoughts Ideas ??
Thanks, Chip
I can thnik of several ways off the top of my head. One woul dbe to use an array to gather the boundary of the objet then use an encoding dial indicator and run the boundary at a set resolution(distance per step) and gather the height info from the encoding indicator on the fly so to speak.
MACH's new Brains gives us a lot of power in the Data Aquisition Dept we just need to learn to exploit it .
The other option would be to gather the bondary and offsett to the inside a set amount then reprobe the boundary to gather the z data for the water jet to follow to maintain the proper head height as it cuts. The trick is it you probe in a preset order then the points file will cut it exactly as you probed it.
Hi , Terry
Thanks for the thaught's, Brain's will be the answer one way or the other.
Thinking about an independent Z up down system with an encoder or switches to follow hight, Like plasma auto hight control's have.
Really need something on the fly.
Thanks, Chip
OK so use the plasma height controll setup and instead of monitoring the arc voltage level use a sliding reohstat mounted at the head to follow the contour height and generate a variable voltage based on the voltage level as a height input then MACH can adjust it similar to the way it does with plasma. ON THE FLY.
Just a thought, (;-) TP
Hi , Terry
Need to look in to that also, Have a plasma cutter, Need to make a bracket for the WJ and set it up. A two for one deal.
Thanks, Chip
Chip this is a little off topic but can you use a waterjet to cut an automobile windshield? If so there is an untapped market for the kit car builders. Many of them need custom glass and have to settle for existing glass due to cost. The existing glass always has to be cut somewhere.
Mike
Chip remember that you cannot attach it to the up and down part of the head the sliding rehostat has to be able to mount rigid to the frame in order to able to move up and down as it follows the contour. That way it can send the voltage signal for height corrections.
OK I just found this thread on the artsoft forum.. what ever happened to the 'Mach3 as a CMM' effort (NOW FIVE YEARS LATER)...???
This is EXACTLY what I need to do...
Is it finished... did you guys give up...?
PLS ADVISE
I will soon be putting together the same thing for my router, as the sheets of material I use aren't always flat! I was going to use compressed air to blow the chip away and help cool the bit, and an ultrasonic sensor to measure the height without touching it. Works an transparent material because it uses sound. Let me know if you would like some info on the ultrasonic sensors we order to use in our products. This along with a Torch Height Controller and it shouldn't be too hard!
Any recommendations on a THC for this application would be great.
Chris
Yes, you can. I've seen a local shop do it on a 5 axis FlowJet. The cost to have it done might send them right back to using existing glass though. The guy running the machine thought it was around $800.
Chris
You won't need to buy a THC. You'll have to build your own using the ultrasonic sensor. All the THC does is compare tip voltage to a set voltage. If the tip voltage is lower than the set voltage, the THC sends a THC UP command. If it's higher, it sends a THC DOWN command. You'll need to build some electronics to read the ultrasonic sensor, compare it's output to a set constant and output to a second PP on the Mach3 PC.
You will also have to create a PID loop to stabilise the function OR you will be chasing it all day. Most THC have the built in pid loop to filter the results and tune out the oscillations.
For the most part it cannot be done without using the THC functions in mach. Only the THC functions can interact with the already buffered moves for Z.
Depends on the output of the sensor ??? Do you have the specs?
The sensors are capable of providing a current or voltage signal, and I believe the voltage range is 0-5V, but will confirm when I go in today. It is trivial to condition the signal IF it doesn't match the THC voltage range. An extremely simple Op-Amp circuit would suit the purpose. Set the gain and you're done. Designing a PID controller on the other hand is not quite so trivial. Not extremely hard or anything, but it would take time that I don't have. Even if I design and/or build a PID, I will have to tune it to get it to work as desired. PID in THC controllers are already tuned for the application. I would much rather just use an existing, proven design then reinvent the wheel. I'll check the specs on those sensors.
A THC seems to fit the bill, unless anyone knows of a simpler, proven solution?
That being said, what THC would people recommend?
Sorry for hijacking the topic ;)
Moderators, can we move these messages to a new thread?
