Mach Discussion => General Mach Discussion => Topic started by: gbecerra on November 07, 2007, 03:12:29 PM
Hello
My problem is that I can only import 50 cutting points to MACH 3 from LazyCam. When I export the DXF file into LazyCam the cutting path shows correctly but when I export the LazyCam File (G-Code) into MACH 3 it shows incomplete. The pattern I have found is that I can only export 50 cutting points in to Mach 3. So, cutting paths greater than 50 points are not exported into MACH 3.
The version of I am using is MACH 3 R2.48 demo version.
I need help tracing this problem? I don't know if it is LazyCam or MACH 3 related?
Thank You in advance for your help.
Hi there.
You know about the limits in the demo version which is 500 lines! Now, i don't know how you count your 50 points, but try to look into the other limit 8)
Best Regards
