Mach Discussion => General Mach Discussion => Topic started by: ViKiNG on August 06, 2022, 01:59:00 AM
I have a AB servo motor that uses an Ultra3000 Servo Drive. I need the software to set this VSD up. I bought the motor and drive second hand and is now quite old. As a result I am having trouble finding the software for the drive. The AB software is called UltraWare and I believe that DSAPro will also work with it. Could someone please either tell me where it can be downloaded or PM with more information
I bought a very similar Allen Bradley servo some years ago and ended up buying the software from Rockwell. The CD cost $200NZD, about $120USD.
Thanks Craig
I can't buy it directly from the web site and I'm not sure that there is a local agent I can but it off.
I believe that there was a free software called DSAPro that will do the same job and I'd be surprised if there isn't someone on the forum that is still using it using that would be able to help me out?
