Mach Discussion => General Mach Discussion => Topic started by: Jegius on April 06, 2022, 11:37:45 AM
Hi everyone,
I want to use screw mapping function on Mach 3, but then I face a problem,when I make a mapped curve for X axis (actually that's the only axis I want to screw map) - auto tool z zero script doesn't work as it should anymore.. In the beginning of auto-zero operation everything is fine - tool moves to home position and then awkward things starts : when tool starts to go down (z axis) it simultaneously moves x axis away too from its home position (my tool probe is in x/y home position). Why is this happening? X/Y should stay at home position as it always was, but screw mapping somehow messes things.
Can anybody light a fire for me?
My auto tool z zero script looks like that : Dim ZOFFSET, ZTOP, ZBOTTOM, ZGODOWN, ZABS, ZUPFINE, Z_SAFE
Dim ToolLen
Dim Tool
Dim SENS_Z, SENS_X, SENS_Y, Z_LIFT, Z_PARK, MAX_DTRAVEL
Dim SPD_FAST, SPD_FINE
' Configuration parameters
SENS_Z = -92.95 ' Sensor Z position
Z_SAFE = -30 ' Safe Z above sensor (for rapid move)
SENS_X = 0 ' Sensor X position
SENS_Y = 0 ' Sensor Y position
MAX_DTRAVEL = 400 ' Max down travel
SPD_FAST = 911
SPD_FINE = 200 ' Fast and fine speeds
Z_LIFT = 1.5 ' Z lift for fine probing
Z_PARK = -5 ' Park after probe absolute Z position
Message( "Tool measuring in progress" )
If GetOEMLed(807) Then
Message( "TC ERROR: X Axis not referenced!" )
End
End If
If GetOEMLed(808) Then
Message( "TC ERROR: Y Axis not referenced!" )
End
End If
If GetOEMLed(809) Then
Message( "TC ERROR: Z Axis not referenced!" )
End
End If
If GetOEMLed(825) Then
Message( "TC ERROR: Measuring aborted" )
End
End If
If GetOEMLed(11) Then
Message( "TC ERROR: Turn off spindle" )
End
End If
Tool = GetDRO(24) ' Get current tool index
' Tool 0 can't be measured
If(Tool = 0) Then
Message( "TC INFO: Tool 0 can't be measured " )
End
End If
WaitForMove
Code("G43T0")
Code("G43H0") ' turn off tool lenght compensation
WaitForMove
' Move to PARK
Code("G0G53 Z" & Z_PARK)
WaitForMove
' Move to XY position of tool correction sensor
' Code("G0G53 X" & SENS_X & " Y" & SENS_Y)
Code("G0G53 X" & SENS_X)
Code("G0G53 Y" & SENS_Y)
WaitForMove
' Get actual Z offset
ZOFFSET = GetOEMDRO(49)
' Rapid go down to safe distance above sensor
Code("G0G53 Z" & Z_SAFE)
WaitForMove
' Probe
ZTOP = GetDRO(2) ' actual Z position
ZGODOWN = ZTOP - MAX_DTRAVEL ' max down travel
Code("G31 Z" & ZGODOWN & "f" & SPD_FAST)
WaitForMove
ZUPFINE = GetOEMDRO(85) + Z_LIFT
Code("G1G53 Z" & ZUPFINE & "f" & SPD_FAST) ' go up Z_LIFT
WaitForMove
' fine probe
Code("G31 Z" & ZGODOWN & "f" & SPD_FINE)
WaitForMove
ZBOTTOM = GetVar(2002) 'get probe activation point
' Lift Z to abs park position
Sleep(50)
WaitForMove
ZABS = ZBOTTOM + ZOFFSET
ToolLen = -(SENS_Z - ZABS)
WaitForMove
SetOEMDRO(42, ToolLen)
Code("G43T" & Tool) ' G43 to sync value in system
Code("G43H" & Tool) ' G43 to sync value in system
WaitForMove
Message ("Z Value : " & ToolLen)
Sub WaitForMove ()
While IsMoving()
Sleep(15)
Wend
End Sub
Message( "Not Yet Implemented" )
