Mach Discussion => Mach4 General Discussion => Topic started by: blauderb on April 10, 2021, 02:52:13 PM
When I do a X axis touch probe command it touches off then is supposed to retract 1.0625 but it only retracts 1.0593, its always off the same amount no mater how many times I try it. Any ideas of where this variance is coming from?
I'm running Mach4 ver. 4612
Hey message support@machsupport.com and I'll try to give you a hand.
I managed to get it finally by slowing down the probe feed rate speed from 5 to 1, now I’m only off .0002 and that’s close enough when you’re working with wood.
Thanks.
