Mach Discussion => Mach4 General Discussion => Topic started by: KentCNC on March 23, 2021, 11:40:57 AM
I have two very simple question that I cannot find answers to.
1) How do I exit a screen script. I have a simple script add to the button up script. I have an If statement that when true I want to exit the code and not continue with the lines below it.
2) I want to use mc.mcCntlSetLastError(inst, "Yadda yada")to display a message to the user and not require an acknowledgment via a message box. I have the message at the beginning of a screen script. Later in that script I have a FOR loop that I am treating as a timer. The problem is that the message will not be displayed until the end when the timer completes and the rest of the routing finishes. How can I get that message to appear as soon as it is hit in the code and not wait for completion of execution of the entire script?
Not sure I know what you mean with #1. Are you talking about a conditional cycle stop?
But #2 is that the button press is a GUI event. And the GUI cannot be updated while it is processing a GUI event. It is the same thread of execution.
So you have to get creative. Maybe have a global screen script variable (defined in the screen load script), a string variable that will contain your message. Than an addition to the PLC script that watches the string variable to become non empty and when so, , uses the string variable in a call to mcCntlSetLastError() and then finally sets the string variable to empty.
screen load script:
myMessageVar = ""
PLC script
if (myMessageVar ~= "") then
local inst = mc.GetInstance()
mcCntlSetLastError(inst, myMessageVar);
myMessageVar = ""
end
Button script:
myMessageVar = "Display this now!!!"
Steve
Thank you for that response. The first question may be so basic that it is easy not to understand what I am asking. If I wrote a subroutine in Visual Basic and had logic that determined a need to exit the subroutine, I would use an Exit Sub command. Any node after that command would not be executed. Is there an equivalent method for exiting the code in a screen button script? Perhaps it just needs to be written as a function and stored it the screen load and called from the button script. I assume you can exit a function using "Return".
Yes, return. All lower case.
if (condition == true) then
return
end
It is a dry read, but the LUA manual may be of some use to you. https://www.lua.org/manual/5.3/ (https://www.lua.org/manual/5.3/)
Steve
I tried return but that did not work. It continued to execute instructions after that IF statement.
Script instructions continued to execute after the return? The return keyword has never failed me. How about posting the entire button script. We will find the answer.
Steve
I have changed my script to use a series of if and elseif statements and eliminated the need for return. So I created the simple script below and like you said the return worked. When I get a chance I will modify my actual routine to determine if I was mistaken or if something odd is truly happening.
if 1==1 then
wx.wxMessageBox ("Return statement next")
return
end
wx.wxMessageBox ("Return did not work")
I went back to my script and sure enough return would work. Not sure what I was doing wrong before. Thank you very much for the responses!
