Mach Discussion => Mach4 General Discussion => Topic started by: Greekart on March 14, 2021, 06:38:25 PM
Hello to everyone,
i have a lathe XZC axis and trying to find how to change the toolpath in Mach4 to recognize C moves than A. Is somewhere and i don't see it, or i can't do it?
Thanks in advance
On the Configure > Control page there is a tab called Axis Mapping that sets up the relationships between your Axis letters and your motors.
Yeah, i know it. What about there? Is something i missing?
There i have C(5) enabled as i want, i know i can use A(3) as my rotary and fix my issue but then i must change all the configurations i have done until now to A. Also i don't like it :).
At General settings i have C Rollover and at ToolPath settings where it say "Display A Axis Rotation" i have Rotate Around Z, here is the trick i want: Change to "Display C Axis Rotation"..
A Axis Rotation is what it is called in the tool path because that is the most common axis. Consider it a misnomer. A rotates around X, B rotates around Y, and the C axis rotates around Z. So what axis does your rotary axis rotate around?
You can try setting it to rotate around Z, as that would be the C axis. But I'm not entirely sure what you want.
Steve
Steve
My rotation axis is around Z and my gcode is output with C than A, in picture "PathZ" is how the toolpath look with C and in "PathA" with A in gcode. That is because Mach4 have at toolpath to recognize A as the rotation Axis, but i don't have A.
I try to find a way to change the letter A to C :).
Panos
