Mach Discussion => General Mach Discussion => Topic started by: M250cnc on October 09, 2007, 05:58:57 PM
Hi I just can't seem to get the soft limits to work.
If i do a G0 past them and it will go past.
I am running in air i have managed to get every thing else working.
I am using vers 3.48 and i know the manual is some way behind.
Anyone got any ideas.
Look in the tutorials section. I tried to cover most of the soft limits settings in the G100 Set-up guide. The softlimit settings will be the same for your set up I think. What kind of hardware are you running?
Hi Brett and thanks.
I am getting the software working in the warm before i go to my cold workshop. ;D
I am using the C11 bob from cnc4pc.
So rigging all hard limits, charge pump, estop, relays, every thing is OK
I set the soft limit OK on the setup page as well but they are just bypassed by a G0 command
Is there a bypass somewhere
Phil_H
I just had a look at the G100 setup i see the problem i set the soft max to what would be the maximum travel allowed on my machine.
So i am going to have a play with the correct settings
Maybe you could change the title of the tutorial to include soft limit settings
Phil_H
Phil soft limits will only work AFTER you have referenced your machine. Mach has to know exactly where it is really at in order to use the softlimits.
Phil_H
Phil_H
There's the clue, i didn't enable softlimits on the first screen Doh!
So its all OK now
Phil_H
