Mach Discussion => General Mach Discussion => Topic started by: waterfx on January 19, 2021, 02:41:48 PM
Trying to use a axis for rotary scan. I aligned X, Y axis to center of plate. My A axis stepper is over rotating for a 360 degree program. One full rotation of plate registers as ~300 degrees in controller. The belts and gears are not slipping and there doesn't seem to be any tangible fault.
then your step'/per for the a-axis are not set correctly.
