Mach Discussion => General Mach Discussion => Topic started by: rceebuilder on October 06, 2007, 09:49:58 PM
I'm trying to do rotary cuttings but I could not go one step ahead so far. First of all my A axis is not working. I enabled A axis and marked as rotary .To see A axis movements I edited a 2d tool path .I have replaced all X letters with A .Then I loaded and run the g code. All other axis works but A axis does not move. Am I doing something wrong? ???
Murat
Hi, Murat
Hear's a xml and an A axis g-code file to try.
You'll need to change pin numbers for your stepper setup.
Hope this Helps, Chip
thank you works fine now.
Murat.
