Mach Discussion => General Mach Discussion => Topic started by: agisthos on November 30, 2020, 05:40:18 PM
All of a sudden my Mach3 has quit working. It starts up, manual jogging movement works, and gcode loads in. But when starting the cut instead of the gcode co-ordinates feeding in line by line, it just stops at the very start.
What do you think the cause of this issue is?
Im using gcode that has been used before, and also tested other gcode I know has worked, and same thing.
can you pls post one of your files, and describe where (line) it stops?
