G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: RadiganKS on November 02, 2020, 08:22:52 AM
I am new on the forum first of all. I am a HS woodworking instructor who just received a brand new Industrial CNC router. We are running MasterCAM 2019 and I am hoping someone on the forum would have a Machine definition file and post. I tried one but I am getting crazy arcs on I and J arcs. Any help would be much appreciated!
If your toolpath is displaying the 'crop circles' then change the IJ Mode (Config / General Config).
Ideally all Gcode files using arcs should contain the G90.1 /G91.1 as appropriate.
Thanks for the reply Tweakie. I don't have an option in System Configuration to change the I and J. I may be looking in the wrong location but as far as I know this is all. Remember I am new to this!
You should look in Mach3 General settings:
Thank you ZASto and Tweakie! That was the problem. I had a chance to work on it after school today and all is good. Cut an engraving toolpath with no problems.
