Mach Discussion => Mach4 General Discussion => Topic started by: alevitt53 on October 19, 2020, 08:24:16 PM
I want to move the machine to a specific coordinate and reset the DRO's.
I am trying to edit the refall function in the screen editor. It seems that no matter what I do, no code
runs after the gcode command.
That portion of the file is attached.
Any help appreciated.
Thank you
Try
mc.mcCntlMdiExecute(inst, string.format("G0 x0 y.5 Z4.5 A180"))
Ok so that did not work.
The line after the move instruction is suppose to set the #3 DRO to 0.00 and it stays at 180.
Try adding a coroutine.yield() after the mc.mcCntlMdiExecute() command...and remove the coroutine.resume().
That'll wait to set your #3 DRO to 0.00 until the MDI command has finished executing.
