Mach Discussion => Mach4 General Discussion => Topic started by: tjd on October 16, 2020, 02:03:10 PM
In short, if I enter a value for 'counts per unit', I can get it move 1 inch accurately
but not for longer distances (9") and V.S.
Initial X motor settings:
counts per unit: 25850.3034 <- generated using Mach StepsPerUnitCalculator to calculate steps per 1 inch distance
velocity (units/minute): 200
acceleration (units/(sec^2)): 24.18
for 1 inch distance. result is 1" +/- .001" - repeatable
for 9 inch distance, result is ~9.25" <- ** BAD ** - repeatable
changed counts per unit to: 25108.1258 <- generated using Mach StepsPerUnitCalculator to calculate steps per 9 inch distance
for 9 inch distance, result is 9" to 9 & 1/64" - repeatable
for 1 inch distance. result is 0.96" <- ** BAD ** - repeatable
This is only a problem for X axis.
Y motor settings:
counts per unit: 25121.7720 <- generated using Mach StepsPerUnitCalculator to calculate steps per 1 inch distance
For distance in y axis, result is accurate for 1" (+/- .001") inch and 4" (w/in 1/64") inches - is repeatable.
Z motor settings:
counts per unit: 25075.2508 <- generated using Mach StepsPerUnitCalculator to calculate steps per 1 inch distance
acceleration (units/(sec^2)): 25
For distance in z axis, result is accurate for 1" (+/- .001") inch and 6" (w/in 1/64") inches - is repeatable.
Based on videos:
- Mach support: Mach4's Steps Per Unit Calculator Wizard - https://www.youtube.com/watch?v=d-xCWDR0Uvg
- Mach4 Motor Calibration - Counts Per Unit - https://www.youtube.com/watch?v=jzYG5VOztFY
Used a dial indicator for 1" distance and pointer pointing at a ruler for longer measurements.
Used simple commands like:
G20
G91
G00 X1
The setup:
- software: Mach 4.
- A LittleMachineShop.com HiTorque Mini Mill 3990
https://littlemachineshop.com/products/product_view.php?ProductID=3990&category=1387807683
- Thomson C7 ball screws. .625" X .2" pitch.
https://www.heavymetalcnc.com/x2/
- motors:
https://www.automationtechnologiesinc.com/products-page/stepper-nema23-3-axis-kits/cnc-stepper-motor-3-axis-kit-3/
- pokeys57cnc board
Tried:
- initially all the motors were set to 16 micro steps. Figured some steps were being ?skipped?. Changed to 4 micro steps for X motor controller.
X settings:
counts per unit: 52221.3064 <- generated using Mach StepsPerUnitCalculator to calculate steps per 1 inch distance
for 1 inch distance. is 1" +/- .005" - repeatable
for 9 inch distance, is ~9.3125" (20/64") - repeatable (worse than 16 micro steps)
- Changed to 32 micro steps for X. Got similar results as 4 micro steps.
- changed velocity for x motor to 100 and acceleration to 5 - made no difference.
- Played with 'rapid rate' at different percentages like ~30% - made no difference.
Any ideas, suggestions?
Your math is the same as mine. Don't know where the disconnect is. '16000' is way too small of a number.
The motor is connected via a "Zero backlash helical coupling" to the screw. Like:
https://openbuildspartstore.com/1-4-x-8mm-flexible-coupling/
What I dont get is why this is happening to 1 axis. The other 2 work fine.
it sounds like you might be loosing steps.
slow down the velocity and accel by 1/2 and try again
I think you are right.
basically have tried that. Just ordered new motors with greater holding torque.
I just figured out something. I come from a programming background. Universal programming truth: '1' =s true, '0' =s false.
Just noticed the table on the motor controller says '0'=on, '1'=off. F***!
