Mach Discussion => General Mach Discussion => Topic started by: guynamedbathgate on October 03, 2007, 03:24:38 PM
one of those days. trying to edit my lathe screenset. I loaded screen4 on my new(old) computer and opened up screen4 like ive done many times on other computers. opens up ok. go to load the 1224.lset for the turn screen set and all I get is a little box with an exclemation point in it. it wont let me close it or do anything else until I force quit the program. so far I havent been able to load any screensets to edit them. Im also having trouble loading screens that Ive edited on other computers and transfered to that machine. They dont show up even though Ive copied them to the same folder as the other screens.
anybody???
man everything with this new computer is a battle. still cant get screen4 to work. but I managed to load a screen from my other computer with the necessary DRO for my toolchanger. loaded the tool change macro into the M6start macro file. and boom. the macro wont run when I enter an M6 t0202 into the command line. Ive checked the toolchanger box in general config. is there anything else I need to do. I can open the macro in the vb script editor and run it and the dro,s start moving like its working, but when I close the editor then its back to nothing.
One of those days indeed.
Chris
I am using the newest version of mach3.
Update. well Im getting closer. If you read my other post you would know that Im also having trouble loading programs. so I got screen4 to work and I think the problems are related. I should start by saying my hard drive is partitioned. I have everything on drive D. so when I went to the tab in screen 4 that sais Mach location it was looking in Drive C.
so I chnaged it to D.
now i got my screen4 working and my toolchanger macro running. but Im back to having trouble loading programs.
I dont suppose that mach is looking somewhere it shouldnt be for the program files and locking up???
dont know if there is a preference I can set or what. Im very very shaky on my knowledge of PC's so Its gotta be basic for me.
I suppose I could just wipe the whole dang thing and start over if I have to.
It's recommended that Mach and all things pertaining to it be on your c drive.
ok well Im gonna just keep posting info as I find things out. so I can load all the test files that come in mach (roadrunner shapes, etc) those all load fine but anything else and it locks and I have to reboot. actualy I cant even shut down the computer I have to power it down manually. I even tried copying the files to the same folder that the mach files are in with no success. this is getting frustrating for sure.
Chris
I see. well I guess I must begin anew.
wiped everything, removed partition, everything on drive C. nothing on my computer except windows xp home edition and Mach3. still having same exact problem with loading part programs. If I try and load any of the programs Ive written over the past year. it locks up and I have to force quit the program. then my computor wont shut down unless I manually power it down.
ill atach the g code Im trying to load that loads fine on 3 other computers running mach
I got it to work earlier today but then it just stopped loading again for no reason I can tell.
I have sent you a personal message.
Brett, I sent you my number. This morning tried opening programs in Machmill and Plasma. they both work. I can pull open any program without a problem (so far)
Its just in Mach turn (the program I need) that it is still locking up. Mind boggling.
Just keeping you posted.
Chris
Thanks for the help Brett. well Ive narrowed my problem down to this. I copied my programs over line by line loading it as I went into the editor. all is working fine and well until I copied a subprogram into the code. Thats what is causing it to lock up. I can open a file with a subprogram in it in Machmill. and machplasma just fine, but not Mach turn. anyone have a clue as to why Mach turn only is having a problem with subs.
Chris
Well I loaded an old version of Mach. so far version 2.24 is working to load programs. dont know why the newer versions arent working. but If the old version works than it works.
Chris
