Mach Discussion => General Mach Discussion => Topic started by: mtabernig on August 08, 2020, 06:36:18 PM
I purchased a new mach 3 and after tuning motors and edge stops I can get nothing to work and everything is getting worst. I like to know if there is a way to reset the entire software to factory default and restart all the calibration again.
I will really be appreciative about any solution.
I wanted to include some information. Everything wha sort of working then I started to get the end tops, the hard stops, to work now I can't get nothing to move. I would like to reset the entire software to the original default....desperate here!!
I work with the demo version of Mach3 for 4 years and nothing like this had ever happened. I am a hobbyist and I decided to take a plunge and purchase the software if Only can start over.
If you REALLY want to start from scratch, just save your license file to a safe place, delete entirely C:\Mach3 folder, download fresh copy of software from NFS site, install it, copy back your license file, and you are "fresh as new".
And, also, if you use some specific macros and/or screen sets, copy those to a safe place before deleting Mach3 folder.
Thank you for the response. However I am using a new computer with a serial port in lew of a parallel port and I had a problem installing the EU 100 or a similar name and someone help me with that. If I remove everything i will have the same problem. I just like to reset all defaults and be done, if that is possible.
Serial port?
What for are you using serial port?
MODBUS or something else?
The serial port on the newer computers disappear, however, I connected the serial port to a UB100" or some near that name" to convert the serial port to a parallel port and be able to assign the pin numbers to the proper port and pins. I did not that existed and I was trying to use an old computer with windows XP. Now I am using a new Dell with windows 10 and the adaptermention above.
Are you using the UC100 connected to a USB port on your PC and does it look exactly like this or is it slightly different ?
(http://cncdrive.com/img/UC100.jpg)
yes, it is exactly like that.
All of the setting-up information for the UC100 is here; http://cncdrive.com/UC100.html
Use their installer and follow the on-screen instructions.
Thank you
Thank you all. I reinstalled mach3 and i had problems with the motors again for some reason, I replace the motors with ones that have more power and work find even with the current cut way down. I think that I burnt the original motors when I live the idling for long times with the machine on but not having anything moving.
Is any command to cut power to the motors after the end of the code?
Sorry; however, I forgot a detail that may be significant.
Before, when I was running the demo version for about 3 years I never had the motors locked up, with current flowing, after the program stop or before start..... is there some difference in this regard on the register version and the demo one?
Not within Mach3 but most motor drivers (ie.. TBA6560 etc.) incorporate a reduced stand-by current setting.
Best to adjust your driver current setting so that your motors outside case temp never exceeds 60 deg.C (even when stationary for long periods).
There is no difference between the licensed and demo versions of Mach3 in this respect.
I will check the option of reduced current on stand by. Right now what I did was to install bigger motors than needed ar a reduced current; they are working just fine but I am afraid and I turn off the power supply to the drivers in standby.
Thank you all for everything, and being willing to share with us ,"newbies", your knowledge and experiences.
Mtabernig
