Mach Discussion => Mach4 General Discussion => Topic started by: devinw on August 04, 2020, 11:50:36 PM
Like the title says, if I change ANYTHING In the tools tab of config, the "apply" button remains greyed out. If you hit ok and come back, none of the settings stay. This is the case in numbers field like "Max tools" or the radio buttons. All the other tabs work and save fine. What the hell am I doing wrong?
Well, Trevor over at Newfangled helped me build a new profile and the settings retain now. Apparently the profiles that come with the PMDX-411 driver are backdated and missing some things, so beware of those following instructions from PMDX starting with their PMDX profile as a basis. I would start with the Mach4-Mill profile in the version of Mach4 you have just installed.
Also, Trevor confirmed the "Apply" button being grey in the Tools tab is a bug, and they are going to work on it. It still saves settings to hit "OK" instead of Apply thouh.
