Third party software and hardware support forums. => HiCON Motion Controller => Topic started by: BillT on May 24, 2020, 02:33:54 PM
My 7766 is doing well and has only failed due to operator error. Otherwise it’s awesome.
My question regards pendant operation. The manual indicate that a pendant can be attached at J10. But this 15 pin connector is not so common anymore. Will a USB wired or wireless pendant drive the axis through the USB port to the 7766, or must a pendant be attached to J10 for the 7766 to move the axis properly?
Using Mach3..
BillT
Got my hands on a usb pendant. It works just fine and does not require direct connect to the controller.
Thanks all..
BillT
