Mach Discussion => General Mach Discussion => Topic started by: DAlgie on March 21, 2020, 03:00:44 PM
Hi, long time since I was last here, shows how reliable this software and systems are. Mach3 lathe, been running great for the last 14 years, the PC finally died, so I got another, reloaded windows XP on the same disk as repair, happy because all my files and settings came back, yay. I go to run Mach3 turn and I think the new PC is not sending anything to the parallel port. Any ideas?
So, i think the problem is related to the point that this was not an install, rather was already on the drive, and i installed a new copy of winxp. I tried running the test file and nothing happens. Help?
Is your new PC 32bit ?
Yes, its win xp, 32 bit.
Nudging this along..... I think the main driver file needs to be reinstalled, so that I get to the point of the all important reboot. I'm sure its something along these lines. What file can I delete and then reinstall to make Mach3 install and go through the reboot sequence? I do NOT want to delete the entire program, this was the point of reloading WinXP as a repair, all my old files are there still.
Never mind, I got it working with the help of a Youtube video made by CNC nutz, episode 104, very helpful.
