Mach Discussion => General Mach Discussion => Topic started by: Pythonsoft on February 02, 2020, 10:48:04 AM
has anyone come across this problem before, when controlling the drives using the onboard jog mode and moving the z axis I have found that at times it seems to stick on and can only be stopped from moving by executing the reset button.
even the relay switch that is on the z axis does not stop it. I have checked on the diagnostics page and the relay seems to be working correctly ,this only seems to happen on the z axis
