Mach Discussion => Mach4 General Discussion => Topic started by: native34 on January 27, 2020, 11:30:19 AM
How can i create and populate elements in Mach 4. I am trying to create a tool table that is not a popup dialog but embedded into the main mach 4 interface. I am also trying to create a screen that has two elements that pull the Gcode files from. One is the USB location and the other is a Specific folder that i can use as a repository to store the G Code files on the PC. I really like how Tormach did it within Path Pilot. I have attached pic to give you an idea of what i'm trying to accomplish
Does anybody have any starting points for me to look into?
You could probably achieve it using wxWidgets.
Take a look at https://docs.wxwidgets.org/3.1/annotated.html (https://docs.wxwidgets.org/3.1/annotated.html) (Note: not everything shown here is available in Mach4 as it uses wxLua)
wxFormBuilder will help you create the Lua code which can be used inside a Lua Panel in the Mach4 screen editor
The wxGenericDirCtrl control is a good starting point, this may do what you want.. https://docs.wxwidgets.org/3.1/classwx_generic_dir_ctrl.html (https://docs.wxwidgets.org/3.1/classwx_generic_dir_ctrl.html)
I have installed wxFormbuilder. How do i use it with Lua Panel to create the form elements and populate them?
Are there any examples on how to use Lua Panels?
in the Lua Examples folder, ProbeToFile have a look at m401.mcs.
It first opens a frame, then a panel within the frame and finally a file dialogue within the panel.
wxLua is a whole learning curve on its own. wxFormBuilder is a very good tutor, you just have to roll up your sleeves and get stuck in.
You can bet it will take several weeks to get to grips with it. Remember this is a software suite that Mach4 incorporates into itself,
its not Mach4 itself. NFS has no part in determining the style and development of wxWidgets.
Given the learning curve of wxLua are you 100% sure you are prepared to put the effort into the two features you want?
I am no expert in either Lua nor, and in particular, wxLua but I will help if you are that keen, but you need to be keen
or it will be a wasted effort.
Since no two individuals will ever agree on what should be included/excluded from a screen set NFS has given everyone the tools to make their own. wxFormBuilder is similar to most Rad dev systems but the linkage to a panel or interfacing with it is not well documented.
I sent a pm to Bryanna suggesting a short step by step video of creating a form in wxFormbuilder and then using it in a panel. Never got a response.
RT
Thank you JoeAverage, I have written programs in VB, VB.Net, ASP.NET. I am no expert in programming and to be quite honest the structure of programs are quite confusing to me, but somehow i seem to make it work in the end. I am willing to put in the work to get these features in my mach 4 screenset. I just wish there was better documentation and examples like there were when is was programming VB. They had pretty clear and concise examples and how you could implements them.
RT
Hi RT,
Bryanna has not visited this forum in the last 8 months so she may have departed NFS.
In Mach4Hobby\Wizards\panelscript.mcs, it shows a bit about using a panel in the Mach4 screen. In main(), mcLuaPanelParent is the Lua panel created in Mach4's screen editor and you're basically setting that as your top level panel.
Hi native34,
I'm glad to hear that you are prepared to dig in.
But there is SUPERB documentation about wxWidgets and its Lua wrapper, its just the documentation is written by geeks, for
geeks and in geekese! I don't know about you but my head spins. In this regard wxFormBuilder is a great tutor, have wxFormBuilder
generate some code and then compare that code to the documentation and viola you have gleaned a wee bit of geekese.
https://docs.wxwidgets.org/3.0/ (https://docs.wxwidgets.org/3.0/)
You may recall:
Its up to you to learn about wxWidgets, its not NFS's responsibility to teach you. It certainly is NFS's responsibility to document Mach4,
Mach4 being their core product, whereas wxWidgets is publicly available and documented software tool/suite that is used in the
creation of Mach4, but NOT NFS's core product.
now consider the two items that you want automated or otherwise built in to your screen set.
You have a directory or repository on your PC which holds all your Gcode?
If you click <Load Gcode> on the standard Mach4 screen what happens? In my installation it opens a file dialogue window
by which you navigate to the desired folder and then to the desired Gcode file. Typically the file dialogue window opens at
the last directory that you used. When you first start Mach that could be anywhere but once you navigate to your
Gcode repository thereafter each time you click <Load Gcode> the file dialogue will open in the repository directory.
In Windows the location of a file is made up of two parts, the filepath and the filename. In wxWidgets the default path is the last
used filepath but you CAN specify a path other than the default. You are in effect using a subset of what Mach (in actual fact wxLua)
does already.
In a similar manner if you require a Gcode file on a USB thumbdrive provide you navigate to the USB drive and indentify the file
it will load.
May I suggest that you confirm that the standard <Load Gcode> button behaves that way, namely opening at the last used filepath.
Assuming that you are happy with that experiment a solution is now in sight.
Replace the one <Load Gcode> button with two others but with a specified filepath rather than the default.
now you are wondering how you set the filepath right? I'm soooo glad you asked ;D ;D
https://docs.wxwidgets.org/3.0/classwx_file_dialog.html (https://docs.wxwidgets.org/3.0/classwx_file_dialog.html)
This is jut one of hundreds of different classes in wxWidgets, but is a commonly used one in Mach because we often
need to navigate to a file either to read, write or append.
I have attached a pic of an excerpt of the public member functions for this class, namely the SetPath function.
I am not really familiar how to use this particular function but that's where wxFormBuilder comes to your rescue.
So i'm using wxbuilder to understand more about the code structure. I imported this code into Mach 4 panel script and i am getting a couple of errors when trying to run the code. I have attached images of the errors.
To use this code in the Lua Panels in Mach4, you must use the Mach4 Panel as the parent.
So change this line
UI.MyPanel1 = wx.wxPanel (wx.Null, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxSize( 500,300 ), wx.wxTAB_TRAVERSAL )
to
UI.MyPanel1 = mcLuaPanelParent
The bolt hole wizard is a good example. It is designed to run as a stand alone wizard OR inside of a Lua panel. To test it, just copy the bolt hole wizard code into the paste buffer and then paste it into the LUA panel's script.
You will see the switch code in there that is similar to what SwiftyJ mentioned. If the mcLuaPanelParent variable is not NIL, then the bolt hole wizard knows that it is running inside a Lua panel. Otherwise, it is running as a stand alone wizard and will create a frame.
It is important to realize that wxFormBuilder will most likely NOT generate drop in code. Use it to generate the user interface and then cut and paste the needed code into your panel script.
Steve
