Mach Discussion => General Mach Discussion => Topic started by: Bob La Londe on November 22, 2019, 07:14:55 PM
I recently set up one of my machines tool tables with tool lengths.
When I execute a tool change it updates the tool length offset and Z DRO, but the tool number DRO still reads zero.
My typical tool change command is T(x) M6 G43 H(x) where (x) is the tool number.
I can manually enter a tool number into the DRO and it applies the tool offset from the tool table if it is not already applied from a command like the one above.
I run into this same issue on both the machine where I have implemented the tool table, and on the test installation on my design computer. I spent over an hour looking for a solution by searching the forum, but was unable to find anything.
Is there some setting in Mach configuration I am missing or do I need to add something to my tool change macros or both?
I found somebody's tool change macro that has what I need in it.
'Tool Change Macro For Manual tool change 09/14 CNC4XR7
DoSpinStop() ' Make sure the spindle is OFF
Code"M09" ' Make sure the coolant is OFF
OldTool = GetOEMDRO (1224) 'Tool In spindle DRO You must add this to your settings screen
'x = GetToolChangeStart( 0 ) ' Get x tool change start position
'y = GetToolChangeStart( 1 ) ' Get y tool change start position
'z = GetToolChangeStart( 2 ) ' Get z tool change start position
tool = GetSelectedTool() ' tool to be changed to
NewTool = tool
If NewTool = OldTool Then
Exit Sub
End If
Code "G53 G0 Z-1.0" ' Move z to tool change position in Machine cord.
While IsMoving ' wait for z to move
Wend
Call SetUserDRO (1224,NewTool)
SetCurrentTool( NewTool ) ' input new tool into tool in spindle dro
Code "G43 H" & tool ' Call tool offsets for new tool
' Verify Tool Change Complete message box
Dim Msg, Style, Title, Help, Ctxt, Response,MyString
Msg = "Please Insert Tool : " & " ( " & GetSelectedTool( ) & " ) " & " " & GetToolDesc(NewTool)
'Msg = "Please Insert Tool Number " & " ( " & GetSelectedTool() & " ) " & " " & GetToolDesc(Tool) ' Define message
Style = vbYesNo + vbCritical + vbDefaultButton2 ' Define buttons
Style = 0 + 48 + 0 ' Define buttons.
Title = "Tool Change Requested" ' Define title
Help = "DEMO.HLP" ' Define Help file
Ctxt = 1000 ' Define topic
'context.
' Display message.
Response = MsgBox(Msg, Style, Title, Help, Ctxt)
If Response = vbOk Then ' User chose Ok
MyString = "Ok" ' Perform some action
End If
'Show user the current tool description
Message "Tool # " & GetCurrentTool() & " : " & GetToolDesc(GetCurrentTool) & " Installed " & " Returning to Tool Change Start Position"
Code "G00 Z.25"
'Code "G00 X" & x & "Y" & y & "Z" & z 'Move back to where the tool change was prompted
While IsMoving
Wend
End
His video is here:
https://www.youtube.com/watch?v=26_N4uwRWmQ
He has a link in the description to a drop box with a screen set and the macro at dropbox. I edited the my screenset instead.
