Mach Discussion => Mach4 General Discussion => Topic started by: mcardoso on November 11, 2019, 10:31:45 AM
I have been successfully using Mach 4 and my computer's embedded serial port for some months now (using the LUARS232 module included with Mach 4). I definitely had some trouble understanding it at the beginning, but now it is a framework for serial communications with my servo drives and works great.
At the recommendation of several members and admins on this forum, I have implemented rigorous error checking and handling throughout all of my scripting. Unfortunately this has been giving me new headaches by... catching errors ;D
I have been able to correct my code to fix all but a handful of errors, mostly thrown by calls to the serial API. Those calls do return error codes to help troubleshoot, however I have been completely unable to find documentation on the RS232 module, either within the Mach 4 documentation or on the greater internet.
For example, I have the line of code:
local err, data_read, size = p:read(4096, 100)
where 4096 is the length of buffer to be read and 100 is the timeout in ms.
This returns the error code "09", but I cannot find ANYTHING to tell me what "09" indicates or how to correct it. I am at a loss.
Any suggestions where to look would be greatly appreciated.
Thanks! - Mike
I believe it's a time error, if I was looking at the correct source code?
https://github.com/srdgame/librs232
jbuehn,
Thanks so much for taking the time to respond. I am not well versed in GitHub. Could you point me to where you found that information? I've been clicking through the files but have not found it yet.
-Mike
line 89
https://github.com/srdgame/librs232/blob/master/bindings/lua/luars232.c
Wow, quite burried in there. Will experiment with the timeout value tonight.
Also it seems like there is a p:flush() command which I might try instead of reading the max buffer length to empty the port.
Making progress! Turns out the Error "09" (Timeout) will occur whenever there is not data available to be read from the buffer. This is a normal condition for me (e.g. read until the buffer is empty) so I need to adjust my error checking to not abort my script if a timeout error is generated.
