Mach Discussion => General Mach Discussion => Topic started by: dorel on September 18, 2019, 03:55:17 PM
Hi evryone,
I have a stepcraft 420 router with diffrent application (printer extruder, milling, touchprobe and laser)
I am using UC100 controler and Mach3 as software but unfortunatly I did not find andy pligins for these application! I know that there are (Stone.. from UK has -they are selling Mach3 with UC100 and stepcraft) but unfortunatly only in UK.)
How can I have this pligin to use stepcraft at fully potential!
Thank you :)
You might start with emailing Stoney and asking them that question.
Just a thought, (;-) TP
What kind of plugin you need?
http://cncdrive.com/UC100.html
If you have UC100 plugin costs nothing, you just had to ask MrG(oogle) :)
maybe I did not put the right question! Is more about Mach 3 profile (I said plugin) for Laser engraveing, for 3d printer extruder and for 3d touchprobe of stepcraft.
Also I wrote to stoney but now answer.
It is doubtful you will ever get a reply from Stoney.
Do you have your laser working (ON/OFF) with your existing Stepcraft Mach3 plugin ?
You have right!
From Stoney the answer was that they have support but only for the machines bought from them!
Whatever!
I will tray to make a copy set-up from UCCNC but I thought there are someone on the forum which is using stepcraft with UC100 and Mach3 and can help me!
